KO PROPO EX-10 Helios q's
#1621
KO Propo staff, you got PM. Thanks.
#1623
I know this question has probably been answered in the middle pages. But it'll take time to search thru them.
I know there is a switch at the Module part H and N. If I set it to H and use digital servos will the unit be operatin at advanced HSR mode? Or do i have to set something else? advanced HSR is the fastest, ryt? thanks!
#1624
Originally Posted by trf_racer
Yes, it's a bit overpriced!
#1626
Originally Posted by JoeyE
Is there a Helios case availible online for order?
#1627
Originally Posted by Yeti35
I am using the Sportwerks/Team Magic one and it works fine for the Helios w/ my Spektrum module on the back. Unless you are looking for a hard case, then I can't help you.
Yea, the actual hard plastic case. My iron dropped on it a while ago and now I want to change it. I heard that you can buy it but no one can tell me where from. Maybe Robert from KO Propo can tell me?
#1630
The aluminum case I bought from Lowes came with the foam liners. Took the tool orginizer side out of it. I think its the same one at Home Depot. It holds 2 aircraft radios nicely, But not too sure if a Helios with a wheel extension would fit might be too big. Measure the radio, then try the local home improvement store.
#1631
I have one of these... i'm sure i've posted about it in here before.
it's an excellent case, has provision for spektrum. and with some mucking about will also fit the radio with wheel extension. has sections for crystals, modules, spare batt box, etc.
I consider it excellent, just the right size, and super light weight.
it's from www.rcmart.com and well priced!
#1632
That's good. But are you sure it will fit Helios with extension?
#1633
From the looks of it, it won't fit the extension unless you cut out a part of the foam according to the extension.
