Like Tree65Likes
TC3 Forum
Old 04-02-2013, 10:07 AM
  #11956
Originally Posted by AudioStylz
... my current rear control arms only have 1 shock location ...
Get some V2 arms and mount the shocks in the inner hole, makes the suspension softer (V1 arms only have the outer hole), I run TC4 shock towers and mount the shocks 2 hole in from out, if traction rolling I will go in one more hole.
drave likes this.
Rojna is offline
Old 04-04-2013, 06:25 PM
  #11957
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Yeah I have a set just never put em on. I have at least 3 more sets of the version 1 rear arms, next week I'll switch out the rear arms to see what I get. I also plan on getting the TC4 chassis braces and at least rear shock tower.
AudioStylz is offline
Old 04-04-2013, 06:35 PM
  #11958
sixace's Avatar
Default spares
Guys,
I picked up a TC3 to play around with in VTA. It's a nice roller, but I have zero spare parts. Anny suggestions on what I should order and keep on hand to keep it up and running on race days?
Running mostly carpet and board contact is likely..
Thanks.
sixace is offline
Old 04-04-2013, 07:02 PM
  #11959
azeroth's Avatar
Trader Rating: 21 (100%+)
inner hinge pin blocks and a spare front bumper that is the only thing i have ever broke and the ocasional bearing going out
azeroth is offline
Old 04-04-2013, 07:05 PM
  #11960
... I also plan on getting the TC4 chassis braces and at least rear shock tower.
You will need the TC4 shock towers if you want to use TC4 chassis braces.
Rojna is offline
Old 04-04-2013, 08:23 PM
  #11961
Rodarbal's Avatar
Trader Rating: 49 (100%+)
Mike's in Carrolton? Here's my list of must haves:
  • Front steering blocks
  • Front block c-carriers
  • Block carrier bushings
  • 4-40 shoulder bolts for the blocks
  • Front a-arms
  • Maybe some a-arm mounts
  • Spur gears
These are parts I've broken or lost (or my son has) as a result of hard wall contact.
Rodarbal is offline
Old 04-05-2013, 05:02 AM
  #11962
sixace's Avatar
  • Front a-arms
  • Spur gears
Yep. Mike's is home track. Run mostly F1, but getting ready for the Ultimate VTA race and the Texas EOS. Thanks for the list, time to order up.
Appreciate everyone's help.
sixace is offline
Old 04-05-2013, 05:56 AM
  #11963
IndyHobbies.com's Avatar
In the case of my son and myself, the word "broken" you used is a little too soft.
In our case, the word "OBLITERATE" would be a better choice.
IndyHobbies.com is offline
Old 04-05-2013, 06:24 AM
  #11964
Rodarbal's Avatar
LMAO!
Speaking of front end parts that go ka-plowie, are there other aftermarket solutions other than aluminum for the steering block and carrier? Just wondering if there are parts made with more forgiving materials available.
Rodarbal is offline
Old 04-05-2013, 08:27 AM
  #11965
SS LS1's Avatar
Trader Rating: 23 (100%+)
[*]Block carrier bushings
What did you mean by this? The TC3 does not use block carrier bushings.
Sixace ....... The stock TC3 hinge pins are weak and will bend in a hard hit. Most new drivers will not notice this and the suspension can bind making handling erratic. I recommend using drill Rod of the same diameter cut to length to replace the hinge pins.
Rojna, when using TC4 chassis braces you do not necessarily need to use TC4 shock towers but many do. We have guys at the track using TC4 braces with the camber links relocated but still have the stock TC3 shock towers.
SS LS1 is offline
Old 04-05-2013, 08:46 AM
  #11966
Rodarbal's Avatar
Hmmmmm... all of my TC3s had ASC3874 block carrier bushings, two per carrier. These are used with the 4-40 shoulder bolts and upper link ball through the carrier to the steering block. Whenever the front end gets obliterated these bushings get lost.
Rodarbal is offline
Old 04-05-2013, 09:07 AM
  #11967
SS LS1's Avatar
Ah, you were talking about the steering bushings not suspension hinge pin bushings like the modern cars have. Now I understand what you were taking about. Funny I have never lost a set of those bushings on any of my 3 TC3 cars. Must be good luck on my part.
SS LS1 is offline
Old 04-05-2013, 09:30 AM
  #11968
Rodarbal's Avatar
Haha! I've never been one for luck. I'm sure it's your superior skills in not tagging walls.
Rodarbal is offline
Old 04-05-2013, 01:49 PM
  #11969
AudioStylz's Avatar
I bought a TC3 parts lot to help stock up on parts. I want to pick up a couple more TC3's preferably some with upgraded parts. There are a few online stores selling TC3 parts still.
Old 04-06-2013, 12:43 AM
  #11970
heretic's Avatar
Wrong. I've used the TC4 braces on several TC3s and there is no need to use TC4 shock towers.
heretic is offline
