Originally Posted by WongTamiya
(Post 11642314)
How do I upgrade the tc3's steering to the ntc3 or tc4 steering system? I don't like the steering rack.
Originally Posted by Rojna
(Post 11642171)
try a softer rear spring, should be softer then front.
so with a silver front go with a green rear, or put the silver in the back a blue up front. Are you using tracktion compound ?? if so full front and rear ?? if so try full rear and 1/2 front or less. but I am using juice full all 4 - so your suggestion of less up front and more rear is to help with the loose rear?? I would have thought more bite up front.. but I guess we are taking care of that with springs correct? I am running 60wt up front and 50wt rear.. NO up travel limit.. wondering if I should get something in there to prevent roll? James |
Thanks for the post Bull, I think I will go silver green.. and lighten the oil. We seem to have a similar car. I am currently running a ballistic 21.5 on a havac.
What FDR are you running.. and a spur pinion please? James |
Originally Posted by Bikerbob
(Post 11643582)
What FDR are you running.. and a spur pinion please? James CTA Kinda evolved with rules for the WCICS series ( WESTERN CANADA INDOOR CHAMPIONSHIP SERIES) wwwwcics.ca Pinion 36t to 40t Spur 60t Robinson 48p ...Mostly used for 1/12 scale. It bolts right in, eliminates grinding motor mount and motor cam for adjustment. You may have to grind out the chassis below the spur if you go to a larger pinion. Outdoor on asphalt last summer I think I usually used a 39 depending on the layout. BE:cool: TJ |
Originally Posted by THEBIGBULL
(Post 11647419)
Pinion 36 to 40 Spur 60t Kimbrough 64p ...Mostly used for 1/12 scale. It bolts right in, eliminates grinding motor mount and tear drop for adjustment . You may have to grind out the chassis below the spur if you go to a larger pinion. Outdoor on asphalt last summer I think I usually used a 39 depending on the layout. BE:cool: TJ |
Originally Posted by beemerfan
(Post 11648218)
I think you may be referring to 48p gears here? Those sizes seem too small for 64p. The 3.85:1 FDR sounds about right for 21.5.
OOOOOOOPPPSSS....My "BOOBOO".....you are so correct it is 48 pitch, At least I got the 60 right!!!!Thanks for catching my mistake. I will go back and edit my post. I just checked the Kimbrough site (Black plastic) and I think I'm wrong again, I think its a Robinson spur (White plastic). "HELP????" me out here!!! I'M:o TJ |
Originally Posted by TeamGoodwrench
(Post 11542699)
I was just looking there and I sure can't find it... unless I'm searching the wrong way. :rolleyes:
http://compare.ebay.com/like/3605404...Types&var=sbar |
(Post 11651928)
Originally Posted by liljohn1064
(Post 11653166)
I used to run these one way shaft bearings in VTA until they were banned and we had to run diff only.
Hello fellow tc3 owners.
I have some questions regarding the tc3 and tc4. A friend of mine gave me his old tc3 so I rebuilt it, cleaned up everything, new bearings and new electronics were dropped in. most likely this will be my vta car. So as I been looking to get some parts and spares I was looking for suggestions. I bought a set of tc4 arms locally thinking they fit but the hinges fit loose. If I get the tc4 arms, hinges and the tc4 ft allow hinge/arm holder fit? What are the major difference between them two and will my tc6 axles and dog bones bolt up if I want to swap to them? Was thinking about ordering a set instead of the allow ones and use regular 4mm hexes and wheel nuts. http://i1211.photobucket.com/albums/...ps7d5fa7c1.jpg |
2 Attachment(s)
(Post 11642314)
http://www3.towerhobbies.com/cgi-bin...?&I=LXNZ71&P=7 The biggest change I've made is aluminum steering hubs. I had an ongoing problem with the top ball/screw stripping out from minor or major wall contact. Aluminum has solved that. These are the ones I got off ebay. How they can ship them in a week for $3.00 from Hong Kong is beyond me, but they did! And, they are quality parts. http://www.ebay.com/itm/ALUMINUM-FRO...ht_1484wt_1093 |
Hello,was wondering if someone can help me out with proper gearing(spur and pinion) be running on a small indoor carpet track(80'X32').I have a novak ballistic 17.5 2200kv motor and a havoc pro esc.It,s for a spec tc 17.5 blinky class.Thank,s
Originally Posted by Bugman
(Post 11674850)
Originally Posted by HeavyD99
(Post 11675021)
You'll need a 72T or 75T spur, I think Robinson racing or Kimberough make them, and a 48T-52T pinion, 64 pitch. You'll need to remove some of the chassis webbing material under where the pinion goes as 48T-52T is so large that it would rub that part of the chassis. If you're not sure what I mean, try that spur/pinion combo, install the motor and you'll quickly see what I mean.
I run a 60/37 in 48p - with the 2.5 internal ratio this gives me 4.05 fdr which works great with most 17.5 not cranked up with the timing.
you want to be AROUND 4.0 fdr - then you want to measure your speed on the track and your temperature of the motor after 120-130 deg f. is ideal. with a small technical track you might want to get the fdr up a bit to 4.1 or 4.2 to get a little more pull - less top end. |
| All times are GMT -7. It is currently 02:35 PM. |
