TC3 Forum
what are drift tires and where do you get them .Do you also put them on the front or just on the back?
drift tires are a super hard compound rubber tires(HPI) or you can use the yokomo drift tires
if you want to save money just use pvs or abs piping and cut it to the liking of your width
you put drift tires on all 4 wheel
oh ya i dont know if your lhs has those hpi or yokomo frift tires but you can get all those (PVC,ABS,Yokomo,HPI) on ebay
Originally Posted by BatJam1
Does anyone know what i would have to do to convert my TC3 to a drift car?
Originally Posted by rpmmaxxed
can anyone suggest a good body to run at socal?
Looking at the stratus 3.0...
Previously ran an S2000 for kicks, but I know it was a hinderance.
Any info is appreciated.
Thanks.
Thanks.
The Mazda is the best all around body... although I ran a stratus AP last weekend which was pretty good at getting rid of the oversteer. Really can't go wrong with either one.
hey henry hows it goin
i just wanted to see if you got my Pm i sent you with my address
just tell me whats up K?
Can some one help me when chossing a Stock motor for my TC3 - needs to be a 27t stock motor , no mod motors please . And I also need a pinion gear too . So any info to help my choice would be great . I will be running on a carpet track , that is fairly tight . oh yeah , cheaper the better .
Try either a trinity PK2 Pro, or a green Machine , or a Monster!As far as gearing we dont know what your running for a spur , what tires, what size diameter they are.Just remember to go down a tooth or 2 if you use the monster.Its more RPM based than the other 2 motors .
Well i don't know the size of the tires , they are foams , and I am using a 72T spur , i bought a 32T pinion , but I think that was a mistake .
if your using 48 pitch gears you should start with a 26 or a 25 tooth pinion,and try to measure the tires diameter i run my tire at 57mm.
Is the bolt pattern the same on the main chassis of the tc3 and the tc4?
no its not just the four bolts that hold the diff down !
hey guys umm... the manual for the tc3 on ae's website is the old tc3 without droop screws and i was wondering if someone can help me out here by telling me where i can get the recent tc3 manual
Batjam1 you seem to know alot about electric car .Im would you run 26mm tire on electric, I wouldn't! Does anyone know.
Thanks newera152
Thanks newera152
batjam1 thats foam 26mm!
