TC3 Forum
Originally Posted by anthony390
he mustve drilled the hole bigger on the motor cam
The stock moter cam is cast alluminium (weaker)...were as the factory cam is machined out of a solid peice and is heaps stronger.
Cheers
I still have some issues with being able to fit an HS605 MG servo in such a manner as the steering will move freely. Ideas?
what do you mean like your servo wont fit right with the given servo holes
can someone name all the losi parts that would fit the tc3 or tc4
did you put a screw on to the servo horn to keep it on the servo.... maybe thats it
well interestingly enough, the servo arm is attached to the bottom of the ball end which is attached to the turnbuckle which connects to the steering rack
oh check your ride hieght or droop beacuse if the tc3 has to much ride hieght the steering ball cups might hit the chassis... the ones im talking about is right under neath the front braces
I recommend using those Losi parts! They are alot sturdier and the bottom king pin doesn't fall out. I'm not sure what other Losi parts can be used but I'm sure there are a bunch of others.
how do you build a Solid front diff from a std diff do you just make it as tight as possible or is there more to it than that?
you COULD do that but i dont think anyone'll reccomend it.
right so im gonna have to splash out on a one way diff then
i already installed losi rear hubs,front hubs and steering knuckles and the front hinge pins with the e-clips so i dont have to use the set screw and i also know the bearings fit
oh ya aries326 i cant find it... i just tried to look for it and i cant find it and so ya your not drifting for a while huh it just started raing here but rumored it wont rain anymore
