TC3 Forum
#6781
irs axle stink just scrape the wall and there it goes there is no
advantage to using them and as far as the spools
i seen guys that can make the a main at a national and disentergrate a spool . these parts are just as prone to breakage then the factory parts the irs axles are diffinatly a cheaper buy!
#6783
td71,
When the KO GP was at SoCal in June, I raced with a 6.94 overall(a core based handout motor), which was 36/100 in 64pitch gears.
#6784
who got the best ceramic bearings for tc3
where can i fine the best ceramic bearings any website or hobbystore have thm please post
#6785
You should check out acerracing.com , they have cerimic berring kits for the TC3.
Trinity should also have some cerimic berring kits for the TC3
#6787
That's not too high. I gear mine 75/28, which is 6.69 GR, 72/26 would be 6.92. That is just about right from what the guys around here are running.
#6791
that got hot
I use an infared heat gun to tell if my gearing is ok for the motor. In my opinion ya can just gear it till it melts. A few times what felt good on the track seemed a little warm when I was done I dont like to get my motors over 150f or so. I know Ive seen on forums that others run em alot hotter but for what I do reliability is more important. thats just what my little experience has taught me.
#6792
might be the drive train is binding.too much load will cause shorting/smoking/frying,as the current can't be converted into motion,thus it converts to heat.
i've geared my stockers(27T) up to mid 5's and 23T stockers into high 5's,no problem as long as there was sufficient cooling between packs.
#6793
Re: Re: QUestion
Originally posted by Flash Gordan
I know Dave Irrgang personally and know everything he makes can take one hell of a beating. His stuff is almost damn near indistructible. How did you ruin 2 spools?
But I broke one when I clip a corner, when the arms broke,one of the wing on the outdrive gave way.
Incidentally I use, IRS Side Braces, Drive cups, spur gear holder, trans. holder and so many more-- all from IRS!
Peace and Happy Racing!!
#6794
Originally posted by Super Steve
My friend smoked his Monster stock with stock spur (72 48pich and 26 48pitch pinion)
The manual reccomends 28 so 26 should be safe i would think?
Was it because his motor had a defect?
O well... at least I TQed and took first...
#6795
Hey lem2 you do know you can order everything straight from the IRS website. The address is:
http://www.teamirsrc.com
Probably will get your equipment faster that way.
