TC3 Forum
#5941
Originally posted by DOTMAN
ESCs have a little drag to them already too. A free drivetrain will only help you.
#5942
Do any of you guys have any pics of your tc3's with warpspeed diff cases? I would like to see them, even if they don't look any different. Also, what material are they machined out of?
#5943
They do not look any different at all, just the stock cases blueprinted and the plastic threads reamed and Helicoil threads inserted. Here is the Demon with cases.
#5944
there is a warpspeed forum
i think that is where all the warpspeed stuff is, like the demon, and the mission
i could be wrong
i could be wrong
#5945
and it is easier to slow a car down when the drivetrain is free, but hard to make it spin faster when you want the top speed
easier on all components, speed control, motor, batteries
#5946
racerdx6 - attached is an excel spreadsheet i made to calculate gear ratio, rollout, and top speed
i reckon a freer drivetrain could only improve times. you might have to adjust your radio or something, but it should definitely help.
#5948
Re: Re: Aluminum outdrives & bearing size
Originally posted by Fasttrak
I really hope you bought the IRS pin cushions to go along with those really nice outdrives. First set I bought I did not know about the pin cushions and after a couple races noticed I had badly notched the out drives where the dogbones ride. This was done using a stock motor, would hate to see what a mod would do. I heard Niftech makes some squared drive units that are real nice, just enver seen or used them.
No problem. I've already purchased IRS's composite CVDs with the pin cushions installed.
#5949
Hi im a TC3 racer from the NW of the UK and here because its so wet usually we race indoors on carpet, my car is fairly stock as the Team TC3 but with an RPM front bumper (saves a load breakages from happening, the walls arnt very forgiving) and aluminum front block carriers. Looking on the site here a lot of people seem to be using a much higher spur, around 100 teeth, i just run the 72 and 75 AE ones, our track isnt huge, i was just wondering why you run them so high? Also how can i free up my transmition, ive seen quite a few people use the warpspeed products, can i just sand my transmission cases down a little to help free up the bearings?
#5950
Originally posted by berger
Hi im a TC3 racer from the NW of the UK and here because its so wet usually we race indoors on carpet, my car is fairly stock as the Team TC3 but with an RPM front bumper (saves a load breakages from happening, the walls arnt very forgiving) and aluminum front block carriers. Looking on the site here a lot of people seem to be using a much higher spur, around 100 teeth, i just run the 72 and 75 AE ones, our track isnt huge, i was just wondering why you run them so high? Also how can i free up my transmition, ive seen quite a few people use the warpspeed products, can i just sand my transmittion cases down a little to help free up the bearings?
People who are running a 100 tooth spur are running 64 pitch gears. As far as your transmission cases are concerned, yes you can do sanding and filing with a Dremel tool yourself. But you have to know what your doing and be very patient. The cases from Warpspeed are only $45 USD shipped in the U.S. A free drivetrain is worth the money and time savings.
#5952
Originally posted by Fuzzy
Berger,
Berger,
yer wife might not agree
anyway,what i normally do is just use penknife,sandpaper and a lot of patience.
Also,sometimes,dont just look at the gearboxes.the gear drives(diff bevel and pinion can also cause a lot of roughness in the drivetrain).An easy way to solve this is to put a slave motor(old,beat up) and power it at 4V-5V's for a few hours.
#5953
Ill see if my friend who runs the trackside shop can get hold of them from the states for me, ive seen the FT drivers cars have very free transmissions, anything else i can do to help that?
#5955
DOTMAN, and others... thanks for the feed back. I will pick me up a set when they come available, to see the difference. Ill be building my TC3 starting next month for the Snowbirds, hopefully these cases can be a part of a competitive car. I didnt do so well last year... lack of track time. Bad thing is, i cant seem to pry myself away from my ASC B4 to wrench on the TC3! Walking into a hobbyshop nowadays, with all the quality kits available for experimentation, is like walking into a strip club with your wife... all the OTHER options are SO distracting!
- Dave
- Dave
