TC3 Forum
#3196
Originally posted by Mike D
[B
The reason for putting CA on the side wall is to stiffen up the lateral movement of the tire and make it work the way it is supposed too. My local track doesn't really generate enough traction to require this - especially in stock. It helps to CA the side wall when you go to big races with alot of traction or when the tire will see higher lateral loads of modified racing. You don't want to use so much glue on the side wall that you end up running on it. Just use enough to stiffen up the side wall of the tire.
[/B]
[B
[/B]
#3198
question
this may be an ignoramous question. . . .
but here goes. . . .
has anybody tried using the one way at the rear??
what will it do to the performance of the car??
Thanks - Lem
Thanks - Lem
#3199
Hi guys. Greetings from Malta.
I see the latest thing is cooling fans by the side of the motor.
Could someone tell me what voltage fans they are using, and what they have them hooked up to.
Regards
Joe from sunny Malta.
Regards
#3200
The fans I have seen are $10 computer cooling fans from radio shack. They are 12v I believe, but will run on our packs also. I have seen them wired to the motor leads, so that they come on with the speed controls, and wired to their own micro size switch directly to the pack itself. I understand on the very hot wind mods that they can drop temps by 20-30deg., thus keeping a hot wind cool enough to finish the round with out melting down all the solder joints. There are also motor companies (Orion) with their own mod motor/fan combos, where the fan mounts directly to the endbell.
adio Shack P/N 273-240, 40mm x 40mm x 10mm
#3201
oooooooohhhh.... look at that.... people getting interested into cooling fans on the motor... Interesting to see how now people see the light after not considering this seriously a few weeks ago
I'll try to get you the references tonight. It seems that they're not that easy to get ( adequate power/weight/consumption ratio). Orion is selling perfect ones, but I don't know the price... I got mine mounted on the car when I bought it.
Believe me, fans on the motor are the way to go.
it's thursday evening... time to go hit the track !
Later
Paul
Later
Paul
#3202
oh yeah, mounting them on a TC3... check the pic I posted a few posts below. Basically you solder the wires on the battery wires, ESC-side. They work perfect on 7V.
Later
Paul
oh well, I'll just post it again. here it is. you can see the fan between the motor and the edge of the chassis. You have to grind the chassis a little bit... btw, it's not my car.
Later
Paul
#3203
I used one from my Trinity TC3 car stand.Its 5volts and does really good.Just add a connector so that it plugs into the battery on the receiver.When you switch the car on it comes on.
#3204
Warp Speed
Does anybody have any info on the Warp Speed chassis for the TC3???
#3205
Re: spaz456
Originally posted by doorman
Spaz456
Mike Dunnigan not Dumas.
He is a tough racer.
His information is very good on set up.
I woundn't hesatate to ask him set up questions.
Mike D.
Keep trying to win that thing.
You'll have your day I'm sure!
Tracy
Spaz456
Mike D.
Tracy
#3206
Fakk2 - Your setup looks good but it seems like it may push a little bit with the stiffer front springs, stock associated rear hubs and camber link locations. I wish my car had a little bit more steering... if I switched anything on my setup I would have put purple springs on the rear and tried some anti-dive in the front.
spaz456 - thanks
spaz456 - thanks
#3207
Regional Moderator
Dingus
those batteries look very close to the shaft. Any problems with rubbing?
You should have a better balanced car I would think
#3208
Gonna try running it soon. I tried pushing the batteries into the shaft, but it still has clearance.
Haven't tried balancing it yet, but I might have to move the transponder, feels a little right heavy now in my hands. Weather's been crappy here.
dennis
dennis
#3209
Regional Moderator
Keep us posted Dingus
#3210
If you guys have seen a recent picture of Josh's car, that's the Radio Shack fan. It's also mounted in the slot next to the motor. He used 2 cap head screws thru the chassis & fan w/nuts on the inside. He then opened the chassis walls with holes for the air to pss thru on the lower part of the fan. Looks slick & works great. All for $10.
