TC3 Forum
#2011
Slim or shim???? Guess it's the same thing....
Running the bubble in the middle of the tweak station DOES NOT necessarily mean your car is tweaked correctly. This just means the car is (weight-wise) is flat. We've found that using the tweak station is a good start, but we NEVER rely on it. Put the car on the track and chances are it's not going to drive with a correct tweak. That is the first step, though. Set the ride height as described by big al. You can then set it on the tweak station and set it, or do the Track Tweak method. Track Tweak is basically setting it on the track and do some hard left and hard right turns. If it's equal, then your chassis and setup is good. If it doesn't, most likely the chassis is twisted. If it hooks harder to one side, you need to adjust the OPPOSITE side to fix the tweak. It takes a little getting used to but it's very effective.
#2012
ooops , thats what happens when you post at midnight ......
SHIMS........
SHIMS........
#2014
Thats why they call me Shim Shady.....
#2015
teflon or brass knuckles there shim?
#2017
inc. RR ride height
#2018
If you never have even steering you will have to adjust your radio. I set mine at 120% dual rate then set the steering epa to 100 then go up or down from there, then when it looks like they are the same(do a circle, make it even both ways) you can turn the dual rate up or down depending home much sterring you want.
#2019
shrekair is right. increase Right Rear.
teamAE has another solution, although your not really fixing the problem, just patching it. Ideally, you want to set up the car so your EPA's are not all jacked.... I have to say that this solution has worked for me in a pinch (at race time).
over gear: Ya, that's the problem with the tweak station. The bubble might be dead-nuts in the center, but your car will still act tweaked. That's when track-tweak comes in. Make sure you set it DURING practice. At race time you may not be allowed the time to play and adjust.
#2021
i had a horrible day at the track on sunday.
I broke in the first qualifer
qualified 2nd after the 2nd qualifier
broke in the 3rd qualifier
and got ran into the wall in the main and broke again
damn , my luck stinks.
Tony:
will the trinity front bumper for the NTC3 fit on the electric TC3
Tony:
#2022
Evening all....may finally get to race this weekend......been almost 2 months since i've raced........AAAARGH
#2023
Kraig: Ya, that would probably work well. Only problem is that you need to buy FOUR scales. Well, I guess you could do it with two. I found some small scales but at $35 a piece, track tweaking didn't seem all that hard....
Might look into it again.....
Type S: Not a direct fit. I guess you could try to modify it but it might take some time.
#2024
Tony,
Had read somewhere that a guy used the Walmart food scales that dieters use...they have enough measurement to work for R/C and are relatively in-expensize ($14.95 each)
What the guy have done was to remove the curved basket and put on a piece of flat plastic for the tray to sit the cars on...just something I had read...
John
John
