Like Tree65Likes
TC3 Forum
Old 05-03-2002, 12:18 PM
  #1786
Dragon Slayer's Avatar
TPHalen......okie dokie......
Dingus.....we have some peeps running mod foam, and if i get a second car, will do so myself.
Dragon Slayer is offline
Old 05-04-2002, 02:03 AM
  #1787
over gear's Avatar
Trader Rating: 18 (100%+)
does more rear toe-in give you higher exit corner speed?
over gear is offline
Old 05-04-2002, 07:37 AM
  #1788
Dingus's Avatar
We have a pretty good 19t class now. Lot of guys are getting bored with stock due to the high traction easy to drive thing. Might just try it myself soon. Looks like fun!!
Dingus is offline
Old 05-04-2002, 11:03 PM
  #1789
rcruv's Avatar
TP - Thanks for helping me with diff adjustment.
Wow, my car now turns automaticaly through the corners.
I've now had it with composite bones. I'm going for MIP shiny bones.
It doesn't matter if I try not to hit anything if somebody just keeps hitting my car out of nowhere and breaks dogbones.
I wonder what will break with steel bones. A arms? Carriers?
Nontherless, racing is FUN !!!
Happy racing guys.
rcruv is offline
Old 05-04-2002, 11:40 PM
  #1790
Super Moderator
Grizzbob's Avatar
Actually, with steel CVD's, I'd say the next weakest link would be the main driveshaft. I've had friends who tried shiny CVD's with a front one-way & they ended up breaking main driveshafts. Personally, I can put up with changing CVD's, & the cost of the composite ones are much easier to deal with. And if I can't afford to do that, then I'll just use the shaft one-way, & use a regular diff up front.....
Grizzbob is offline
Old 05-05-2002, 12:26 AM
  #1791
rcruv's Avatar
Would Ti drive shaft cure that problem?
Then what do you think is the next victim?
rcruv is offline
Old 05-05-2002, 05:39 AM
  #1792
Default Chassis braces
Has anyone tried TC3 without the chassis stiffening braces? I assume that this modification would let the chassis flex a little bit more. I`m starting outdoors season and I think that flex is sometimes good for tarmac. If someone has tried this, please tell me your experiences.
Eetu is offline
Old 05-05-2002, 10:35 AM
  #1793
yodace's Avatar
I broke a Front plastic outdrive saturday. I didn't even hit anything?
In body have any thoughts about way it broke? Please let me know.
yodace is offline
Old 05-05-2002, 01:15 PM
  #1794
dcracer's Avatar
Were you running stock or modified. It's possible it was stressed from a previous hit.
dcracer is offline
Old 05-05-2002, 01:40 PM
  #1795
Super Moderator
Grizzbob's Avatar
rcruv, a Ti shaft might not have any problem with breaking, but it'd very likely weigh considerably more than the stock one does, which might slow acceleration down a bit. As for any other things that might break, I'm really not sure.....
Grizzbob is offline
Old 05-05-2002, 02:32 PM
  #1796
yodace's Avatar
Just built the car.
Somebody at the track told me that I front diff to tight and thats why it broke the front diff outdrive?
yodace is offline
Old 05-05-2002, 02:33 PM
  #1797
yodace's Avatar
I was running stock?
yodace is offline
Old 05-05-2002, 02:42 PM
  #1798
dcracer's Avatar
If you over tightened the diff it is possible to stress the plastic to point of breaking, and power being applied to it would be enough to finish breaking the outdrive.
dcracer is offline
Old 05-05-2002, 02:50 PM
  #1799
yodace's Avatar
Any suggests on how to solve the problem ?
yodace is offline
Old 05-05-2002, 03:19 PM
  #1800
dcracer's Avatar
I just basicly follow the instuctions for building and tightening the diff. Once the diff is in the car, I hold the front wheels and try turning the spur gear, and adjust it so that it does not slip. Then do the same for the back.
dcracer is offline
