The Speed Passion Thread >
Like Tree57Likes
Old 02-20-2013 | 10:00 PM
  #11251
samnelso's Avatar
I see Reventon Pro SF000222 is ROAR approved. Should this be SP000222?
samnelso is offline
Old 02-20-2013 | 10:07 PM
  #11252
duckman996's Avatar
I need some help...
I have a Speed Passion GT Pro Stock ESC and a SP Multi ESC program card, however, the program card has the Hobbywing V3 software on the card and I do not know how to change it back to Speed Passion?
What would the latest blinky software that I can use on this speed controller be?
Thanks. I did a search on this thread and I could not find an answer.
duckman996 is offline
Old 02-20-2013 | 10:20 PM
  #11253
Default Reventon Pro -No beeping sound in setup
I just got a new Reventron Pro & when I was doing the controller setup it was suppose to beep, but mine was not beeping. It did do the setup properly. Anyone have the same experience as I do?
thx.
DJGonzo69 is offline
Old 02-21-2013 | 02:13 AM
  #11254
thx.
ABC connection is correct? What motor do you use?
WMGary is offline
Old 02-21-2013 | 04:59 AM
  #11255
Originally Posted by walste
Enyone have A good setup with the Reventon PRO, for 17.5 boosted?
I Run the ThunderPower 17.5T.
What FDR, and ESC settings should i start with, for A small/medium track.
Enyone !?!?!
walste is offline
Old 02-21-2013 | 02:31 PM
  #11256
coretex's Avatar
I tried some friends SpeedPassion Program card but it did not work. Probably the wrong version or something.. I guess I have to buy a Reventon Series Smart LED Program Card.
I have trouble finding this product on the web: Speed Passion Product code SP000007. Do anybody know of a store that has this in stock?
coretex is offline
Old 02-22-2013 | 12:12 PM
  #11257
Roar fixed that....thanks for pointing that out.
Solara is offline
  #11258
Enyone !?!?!
http://www.speedpassion.net/us/escsetup.asp
Look under 1/10th stock TC setup...
Solara is offline
Old 02-22-2013 | 07:28 PM
  #11259
jdawg81's Avatar
I just installed the MMM 17.5R motor and I'm having a problem with the motor stuttering when slowly accelerating from a standstill. I'm not sure how else to describe it but it's like it just stutters and doesn't move until I pull on the trigger more. Once the car gets going it doesn't seem to be an issue anymore. I'm using a Citrix Stock Club Race ESC and I did not have this problem with the Ultra Sportsman V2 17.5 motor I was using before. I also double checked the sensor wire connection and that I had all the proper wires from the ESC going to the motor. I have tried using a new sensor cable and adjusting the timing but the stuttering doesn't go away. Does anyone know how I can fix this? I'm starting to think maybe the Citrix ESC doesn't work that well with this motor but I also tried an Orca Spark ESC and the problem was even worse. A lot of the time the motor won't even move at all and it makes some kind of high pitched sound.
jdawg81 is offline
Old 02-23-2013 | 11:41 AM
  #11260
i got a problem with my reventon pro running my LRP x12 17.5 sensored.
With the sensor cable plugged in the under hard acceleration on the ground the the motor lurches back and forward and the red and orange led flash (see youtube vid :http://www.youtube.com/watch?v=Uc4GyIPFMjo ) if i have the car in my hand there is no issue.
If i unplug the sensor cable i do not have the issue. Is there a known issue with the LRP 17.5t ? as i had this esc hooked up to a speed passion MMM v3 17.5t with no issue with the same sensor cable.
*EDIT : more testing and using blinky mode i do not have a issue but under every other mode i do*
atmosphere is offline
Old 02-24-2013 | 08:51 AM
  #11261
JoeyE's Avatar
Have a Reventon Pro in Stock 0. How do I add more bakes in the program?
Running 17.5 Blinky.
Thanks~
JoeyE is offline
Old 02-24-2013 | 09:15 AM
  #11262
Thanks~
Do you mean drag break? (is when you have the released it from throttle to neutral) or when you apply break's?
Team_Elli is offline
Old 02-24-2013 | 10:04 AM
  #11263
hi i have reventon pro with a thunderpower 17.5t in stock0 whats good set fdr and motor timing for med to large trach (aldershot)
tcboy1983 is offline
Old 02-24-2013 | 07:09 PM
  #11264
JoeyE's Avatar
Its like when I come up to a corner too fast and just want to jab on the brakes, I have none.
JoeyE is offline
Old 02-24-2013 | 08:10 PM
  #11265
Pick up a programming box or find someone at your track that has a programming box. You can increase the amount of brakes via the programming box.
thunderbt3 is offline
