The Speed Passion Thread
One more thing, until i dont touch trhe update firmware button all works fine i can change all settings on speedo etc. But when i push the update software button and no related file is instead of software update files all reventon interface is frozen and i cannot change settings anymore... what is going on? is that problem with speedo? or just need to erase all software on speedo and upload it again? But how?
Reventon Programming cards (the blue one) will not work on the Non-Reventon ESCs.
SP Hi Tech, and uninstalled and all installed in my pc ye all again and still the same,
FAN works the drive is turned off and on with no problem but when I give firware UPDATE: not related file and also puts REVENTON CAN ONLY UPDATE firware
#2 Somehow, my solution is, using another radio system like a Futaba, Sanwa JR or whatever, just not Spektrum...
I have Futaba 4pks and shutting down...
Also, if you are running SAVOX servo with that...good luck, please get a glitch buster and hope that will solve the problem.
I have Sanwa, still not working correctly...
#3....any kinda of shut down or weird acting....please UPDATE the software of the ESC. We just released the 1.1.0-V20 firmware, and the recommended software to use are the following.....
Software updated, not working correctly...
#5....after loading the software, please do try it with NO LIPO CUTOFF and report any unexpected shut down. I have been to at least 3 weekend of racing and tech supporting on site for at least 20-30 REVENTON user and I have not hear/seen a power shut down issue...I believed the lastest software already took care of that. And I believed only a few were running without lipo cutoff...most of them are set to 3.4V/cell....if there are no more unexpected shutdown issue, you can turn it back on to 3.4V or lower.
No lipo cut, still shutting down. But it don't shut down if I try to...
Two Reventon Pros in our club with same problems. 1/10 Pro stock class (10.5 GM brushless, non timing.
If your ESC cannot shut off.....please check and see the RED LIGHT on the ESC is on or not......IF there are no RED light, that means, your NEUTRAL POINT of the ESC is off........check your radio. WHen you calibrate it the 1st time with the radio, the ESC will register the idle/neutral point...but if your radio was set THROTTLE trim like forwarded by 5%...that will throw off the neutral point and the red light will be off....hint the shut off is disabled. Because the ESC is thinking you are in motion....RACING that is.
I have a quick solution...I usually PUSH the brake (throttle forward) and usually the RED light will be turn on.....THEN you can switch off the ESC.
This happened to SP TECH when he like to have the car ROLL (instead of neutral)...so he set his throttle trim to forward by like 25-30% so the car will have the rolling start.........but the down side is, it will not allow you to turn off the ESC because the ESC is thinking you are still racing. My quick fix to him is have him to PUSH forward on the radio's trigger (BRAKING) and made the red light to turn on...THEN you can able to turn off the ESC.
Give that a try...and I hope that is the reason.
Make sure the USB driver are installed and the LCD card MUST BE UPDATED to the version 2.5
LIPO cannot be connected.....
these 2 items must be OFF and DISCONNECT from the connector...
ok, thanks for answering SOLARA, I will uninstall everything right again and again download software V20.
LIPO the FAN and are disconnected and the LCD card updated to version 2.5
Would be nice to have some more brakes. With an X12 7.5T the speedo is not getting above 65 degrees so I'm sure it could cope with some more braking power
He was using that software on the indoor carpet track and it actually tear up the carpet at couple areas....(that he ended up helping to patching the carpet after the testing..)
I'm here, nothing SOLARA not work, desibstalo what I install everything right and still leave me the same thing when I get I UPDATE FIRMWARE ... No related file
I can not put one photo for insufficient messages, my email is [email protected]
