The Speed Passion Thread >
Like Tree57Likes
Old 10-23-2012, 03:45 PM
  #10426
Originally Posted by Penz316
I think the reventon pro doesn't work with 17.5
We have to wait for the software update
the reventon pro works great with the blinky/non-timing motors,,,i use it in my Cougar SVR. its even smoother and has more brakes that the pro-2.
gdcopbdcop is offline
Old 10-24-2012, 05:01 AM
  #10427
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Depending on the 17.5 motor you are using it works just fine if you are running a mmm v3 you might need to change the sensor board
Marcos.J is offline
Old 10-24-2012, 05:19 AM
  #10428
mtbboy's Avatar
Hey Marcos,
Could you post a link to reventon specific setup sheets please?
Thanks.
D.
mtbboy is offline
Old 10-24-2012, 07:51 AM
  #10429
Trader Rating: 38 (100%+)
Change the sensor board to what? My Reventon Pro got sent back and I'm hoping to get the replacement soon and will be running a 17.5MMM in my touring car with it.
linkless is offline
Old 10-24-2012, 08:09 AM
  #10430
Super Moderator
Marcos.J's Avatar
I would get the yellow and green board and see which one works for your track.
As far a links for set ups I'm not sure if the website is updated with a reventon pro set ups yet . I haven't check the website in a few days. But software is still being tested so the set ups that I have posted might be changing
Marcos.J is offline
Old 10-24-2012, 08:43 AM
  #10431
Is there going to be a software update to fix this in the future? I prefer to run low timing in my motors at the local track and don't see myself putting the yellow or green board in the MMM when the stock one works just fine.
linkless is offline
Old 10-24-2012, 09:20 AM
  #10432
M-Technic's Avatar
Trader Rating: 15 (100%+)
Are you running blinky or boosted?
M-Technic is offline
Old 10-24-2012, 05:17 PM
  #10433
huaicin's Avatar
check your brake force with the LCD box
Thx for the reply.. I can brake my car now, but is it the trigger in neutral position naturaly? But I want to push the trigger to apply brake. Is it possible?
huaicin is offline
Old 10-24-2012, 05:51 PM
  #10434
Running 17.5 Blinky touring car.
linkless is offline
Old 10-24-2012, 08:08 PM
  #10435
vr6cj's Avatar
Trader Rating: 124 (100%+)
Ran my Rev Pro this last weekend with a Trinity 17.5 D3 and zero issues. Won my main with it. The esc is so damn smooth. Like zz top Beavis smooth!
vr6cj is offline
Old 10-24-2012, 10:33 PM
  #10436
Super Moderator
Marcos.J's Avatar
You adjusted the drag brake , bring the drag brake to 10% then go to brake force and put it at 70% to start and go from there.
Marcos.J is offline
Old 10-24-2012, 11:20 PM
  #10437
Radio Active's Avatar
[QUOTE=SP Tech;11350476]
Originally Posted by Radio Active
I'm trying to find the sweet spot for a Speed Passion 1 cell 10.5 in blinky 12th.
It seems you started answering me, and then deleted it maybe? Any advice is useful.
I'm confused as to what timing/rollout combination I should be looking at. One guy is running 87 mm with a V3 at 10 degrees, but even for 72 mm my 1 cell comes back really hot.
Radio Active is offline
Old 10-25-2012, 12:25 AM
  #10438
huaicin's Avatar
I can find drage brake but I can't find the brake force menu.. Is it Percentage Brake - ABS?
huaicin is offline
Old 10-25-2012, 04:32 AM
  #10439
Geberit's Avatar
That's a nice surprise, SP Reventon PRO for 139 € card included! And that's in Europe
http://www.fast-webshop.com/tonispor...nton-PRO-Titan
Geberit is offline
Old 10-25-2012, 06:34 AM
  #10440
M-Technic's Avatar
Then no, it's not a software problem. It's just the fact that blinky likes to have a lot of motor timing, and to achieve that with SP motors you have to buy optional timing boards. However, you can still make it work with the stock red ring. I've run it before and was competitive. You just need to run a lower gearing than average.
