The Speed Passion Thread >
Like Tree57Likes
Old 09-25-2012, 03:21 PM
  #10081
Trader Rating: 17 (100%+)
Originally Posted by Marcos.J
Please do not bench test the new software I guarantee this will happen to you!! Lol!
Told you NOT to do that....140,000 rpm on peak and it will blow up any tires if they are not on the ground.
Solara is offline
Old 09-25-2012, 05:25 PM
  #10082
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Lol
Marcos.J is offline
Old 09-25-2012, 09:04 PM
  #10083
What are the new improvements for the reventon pro? Can it be compared with the LRP, Tekin, Orca ESC's?
kikoy is offline
Old 09-26-2012, 12:33 AM
  #10084
jychow's Avatar
Hi. Mind to share what tire is that? Thanks.
jychow is offline
Old 09-26-2012, 01:11 AM
  #10085
blade072's Avatar
Trader Rating: 98 (100%+)
Couple more weeks....the current software is only good for 4.5 to 9.5 motor.
low turn motor use high hybrid boost active percentage and hybrid boost maximum k value....high turn motor use low high hybrid boost active percentage and hybrid boost maximum k value....but I am still testing it on 13.5 and 17.5 now, will update everyone here soon.
thanks solara....
blade072 is offline
Old 09-26-2012, 01:58 AM
  #10086
Skitee's Avatar
Looking at the rim design and the purple insert, I'll guess that it's a Solaris Spec pre-mount.
Skitee is offline
Old 09-26-2012, 03:54 AM
  #10087
Default Reventon mod software
Well after the new stock1 for mod software was uploaded to the Speed Passion website its now gooooone. What's up with that???????
Bumpy is offline
Old 09-26-2012, 04:27 AM
  #10088
Super Moderator
Marcos.J's Avatar
That's correct
Marcos.J is offline
Old 09-26-2012, 04:28 AM
  #10089
Super Moderator
Marcos.J's Avatar
I noticed that I wanted to download the manual and it was gone well at least I was able to download the software
Marcos.J is offline
Old 09-26-2012, 06:53 AM
  #10090
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Solara or anyone, can you answer the following?
Originally Posted by Cain
I am right now looking at the following:
1/12 Stock Blinky: GT2.1 Pro Stock, GT2.0 LPF,
1/10 Touring Blinky: GT2.1 Pro Stock, GT2.0 LPF, Revention R
I know this overkill, but I do rotate electronics at times so I need stuff to be versatile and the only thing where "stock" is done is indoors in the winter.
For 1/12, am I correct in assuming that the GT2.1 Pro Stock and the GT2.0 LPF can use the TQ Booster without issues?
Lastly, am I correct in assuming there are no issues as far as fitment, etc with using the 12.5mm rotors in the V3.0 series of motors, regular and 1 Cell? (sorry, I know this sounds dumb, but I don't want to order something and essentially have a paperweight)
Also, Can you set the Cirtix ESC to a cutoff voltage level safe for 1S lipo usage with a programmer or something?
I am assuming you can set a voltage cutoff level for 1S lipo usage on the GT2.0/2.1 series of ESCs, regardless of type (Pro, LPF, Pro Stock), is that correct?
I got in my 1/12 stuff, tried the novak edge ... I want my speed passion stuff and programmer card! No more multi-color light show to go off of!
Cain is offline
Old 09-26-2012, 06:56 AM
  #10091
TimPotter's Avatar
Trader Rating: 15 (100%+)
Marcos.. I would guess that was a well worn tire. I doubt a brand new skin would do that...
TimPotter is offline
Old 09-26-2012, 07:11 AM
  #10092
tazfam2's Avatar
Trader Rating: 54 (100%+)
It has a ton of boost up to 150000 rpm
tazfam2 is offline
Old 09-26-2012, 07:16 AM
  #10093
It is back online now...now is V17. Daily improvement I would say...
Solara is offline
Old 09-26-2012, 07:19 AM
  #10094
Our last generation ESC GT2 PRO is already par with LRP, Tekin ORCA and Hobbywing...the new one is only be better.
I can only say this...when I was testing boost mod with 4T motor 2 days ago, at one point, I was passing the 1/8th on road nitro on the straight..passing it. I would guess I was running around 70+ mph at that point....
But of course, after that straight pass...I blew the rear diff, then stripped the rear belt twice, and totaled the car because I lost brake....
Solara is offline
Old 09-26-2012, 07:20 AM
  #10095
Tim....try a new tire, I can guaranteed you it will do the same. It is that crazy....
Solara is offline
