The Speed Passion Thread >
Like Tree57Likes
Old 07-27-2012 | 06:31 AM
  #9736
Ritchie T's Avatar
Arrow
Is the release date of the Reventon Pro anytime soon?
Ritchie T is offline
Old 07-28-2012 | 09:02 AM
  #9737
Shooting for September, testing boost software now...
Solara is offline
Old 07-28-2012 | 10:30 AM
  #9738
Default reventon R esc
hello
I just bought reventon r esc with ultra sportsman v3 17.5r motor.
After calibrating, the motor wouldn't respond at all.
servo channel works fine. When i set the range of throttle the motor seems responding the clicking of reset button.
I tried the clibration with the motor connected & without.
Did I miss anything?
aackjw is offline
Old 07-28-2012 | 02:20 PM
  #9739
Ritchie T's Avatar
Arrow
Thanks Solara.
Apart from lower turn motors that it can handle is there anything new going on
Old 07-28-2012 | 09:51 PM
  #9740
Post deleted - needed to be in the off-road forum.
AntiGooch is offline
Old 07-31-2012 | 08:55 AM
  #9741
Just to be sure I got it right. The reventon S will NOT be able to use timing advance and turbo/boost like the old gt 2.0 , right? The R and the pro are the only ones capable of running the "stock 1" profile ?
mrtoulouse is offline
  #9742
Deleted due to double post.
Old 07-31-2012 | 09:56 AM
  #9743
Originally Posted by aackjw
hello
Have you try to reverse the channel on your throttle setting on your radio...? Give that a try and see that works or not...
Solara is offline
Old 08-01-2012 | 02:32 AM
  #9744
AUSCAN's Avatar
Hi. I'm running a V3 one cell 21.5 motor in blinky mode in my Serpent S411. I'm interested in boosting the timing by putting in a timing board, say a SP000058 ( 30 deg. )? I'd be interested to hear anyones opinions on whether or not this will work.
Thanks in advance.
AUSCAN is offline
Old 08-01-2012 | 02:37 AM
  #9745
AUSCAN's Avatar
I'm also thinking of changing the rotor out to a #RS13802 12.3mm Rotor, Purple Ring. I can\t afford to lose much in the way of torque but would like to get some more revs out of my 1 cell 21.5 motor.
Has anyone tried this or have any comments to make?
Thanks again guys
AUSCAN is offline
Old 08-01-2012 | 06:28 AM
  #9746
M-Technic's Avatar
Thanks in advance.
Yes it will work great. The 30* yellow board is a good choice.
M-Technic is offline
Old 08-01-2012 | 07:43 AM
  #9747
The S is capable to do software update, just like the R and the PRO. However, since the S is just a 40A unit, even there will be a boost software coming and is capable to be run on the S...but the performance should NOT be even as good as on the R and the PRO. Again...if running a 40A ESC has the same power as the 70A and 140A unit...why buy the better unit?
But I am not sure we will release a BOOST software for the S...simply because I don't think the S can do anything good about running BOOST software. But we might do a very mild version of boost software for the S.
Solara is offline
Old 08-01-2012 | 07:47 AM
  #9748
Thanks in advance.
Thanks again guys
These 2 options are fairly used by our driver. Go ahead and determine your timing and gearing base on the size of your track....keep an eye on the motor temp and use fan is necessary.
Solara is offline
Old 08-01-2012 | 08:51 AM
  #9749
Cool thanks man, just like i thought :-)
Do you have any idea as to the release date in europe for the R version. . Also will the pro be available in black, cuz it kinda bothers me that the R is not :-D Silly, I know, but the orange, judging by the pics at least, seems to not go too well with xray orange, and thus black seems to be the only logical color option for us T3 drivers.
thanks for your time and service :-)
Old 08-02-2012 | 09:21 AM
  #9750
whats the eta for the Reventon Stock Club Race ESC
or
will the Cirtix Stock Club Race ESC be back in stock any time soon ??
Also will any of the old set up boxes work with the Reventon Stock Club Race or will I need a new one for it ??
Rojna is offline
