The Speed Passion Thread
#8132
what is a good starting point in gearing, v3 1s 17,5motor, boosted
touring on a small carpet track
#8138
If you are running boosted "spec", so 10.5, 13.5, 17.5, etc... any of the ESC's (GT2.0 PRO, GT2.0 LPF, or GT 2.1) will work great.
Jimmy
#8140
hi
im wondering what type of fdr is a good starting point for the sp MMM 4.5 using sp esc
thanks
thanks
#8142
if i do run boost what should i run
#8143
Got an issue with my club racer 21.5 SP motor/ESC. I slid into the barrier sideways on the ESC side (its in an F103W) didn't hit the electronics though and since then the red light (low battery voltage) light blinks. Also, the motor wouldn't run unless you spun it by hand. I picked up another 21.5 motor, recharged the Lipo and I still get the red blinking light. I reset the ESC per the instructions and still it blinks. Swapped out the sensor wire too. Batteries are charged and work fine in other cars. Ideas?
PS. Just got a new Cirtirx ESC in. Hooked it up and I still have the flashing red light. Now I'm really confused...
#8145
Can I use the 2.1 Prostock ESC (not EX) in a 1S WGT car with 6.6v LiFe Receiver Pack or is it better with a TQ booster (red lead only)?
Any one have a WGT 13.5 setup using which software? Gearing/ rollout? Motor? (I have a nemesis right now). Any starting point would be great!
Ivan
Ivan
