Originally Posted by Lowrance
(Post 9802583)
Anyone have leads to a NIB GT2.0 LPF or a GT2.1 Prostock in the states.
(Post 9802583)
Originally Posted by hanulec
(Post 9799834)
any idea when 17.5 MMM motors will be back in stock at Speed Passion USA?? they served me well at IIC -- and I'll like to pick up a few more. thanks! -mike
GREAT... I need another GT...
Originally Posted by Solara
(Post 9802782)
About 2 weeks...as well as more GT ESC.
what is a good starting point in gearing, v3 1s 17,5motor, boosted
touring on a small carpet track |
Looking at swapping from a hobbywing to a Speed Passion ESC
Can someone recommend which version is best for boosted racing Cheers |
GT V2.1 for Boosted Spec...
Originally Posted by lethallee69
(Post 9803160)
(Post 9803160)
Can someone recommend which version is best for boosted racing Cheers If you are running boosted "spec", so 10.5, 13.5, 17.5, etc... any of the ESC's (GT2.0 PRO, GT2.0 LPF, or GT 2.1) will work great. Jimmy |
(Post 9803160)
hi
im wondering what type of fdr is a good starting point for the sp MMM 4.5 using sp esc thanks |
Originally Posted by jake95
(Post 9809960)
hi
if i do run boost what should i run
Got an issue with my club racer 21.5 SP motor/ESC. I slid into the barrier sideways on the ESC side (its in an F103W) didn't hit the electronics though and since then the red light (low battery voltage) light blinks. Also, the motor wouldn't run unless you spun it by hand. I picked up another 21.5 motor, recharged the Lipo and I still get the red blinking light. I reset the ESC per the instructions and still it blinks. Swapped out the sensor wire too. Batteries are charged and work fine in other cars. Ideas?
Thanks :nod: PS. Just got a new Cirtirx ESC in. Hooked it up and I still have the flashing red light. Now I'm really confused... |
http://www.youtube.com/watch?v=KdjNk...&feature=feedu
Howard Low laying it down! |
Can I use the 2.1 Prostock ESC (not EX) in a 1S WGT car with 6.6v LiFe Receiver Pack or is it better with a TQ booster (red lead only)?
Any one have a WGT 13.5 setup using which software? Gearing/ rollout? Motor? (I have a nemesis right now). Any starting point would be great! Ivan |
| All times are GMT -7. It is currently 04:39 PM. |
