The Speed Passion Thread
#7067
#7068
For example...depends on the size of the track, you will find 13.5 motor lap time is within 0.5 sec per lap slower then a full mod motor lap time. 2-3 years ago, that is not the case...MOD is always faster by alot.
#7069
Are you saying you want to run it with 4.45 final drive..? Depends on what software you are running...for no timing, I think you can OVER GEARED. For full boost software...you are WAY WAY WAY over geared....
But if you are drag racing for a short period of time...I think it is OK.
#7070
i ran the new softwere today in my T3 with 6.5SPv3 motor
wheel spin along the straight it was crazy fast
I used the 10.5 set up and turned it down a little , it was really powerfull and not too warm , it was at 70 degreesC after 5 mins without fan the speedo was 80 without fan , i have now put a fan on it
#7071
Driving and car set-up skills come into play also, and my feeling of the electro world is that drivers always only are blaming the ESC if they are not fast enough....
#7072
I outrun anything with my 1/12 scale Serpent car with Hobbywing 1S ESC except for 1 Tekin guy, so stop comparing ESC's....
good luck with your 1/12th scale this winter we now have Speed passion softwere to compair with other stock softwere see you at MACH indoor in the winter
#7073
Yep, looking forward Phil in comparing our firmware, but... again, driving skills come into play.
There is nobody as fast as John with his GM powered car, but again, those driving skills (or the lack of them) are killing his laptimes....
#7074
And because this is the SP thread, you are off course allowed to bash any other brand if you want, I understand...
see ya in the winter
#7075
just joking around. we now the tekin guy so!
#7076
and my speedpasion is faster as your hobbything! lol
#7077
Solara, updated both my speedo's /me like
Thanks again for you support.
#7078
#7079
am running SP GT2.0 on my 12th on 1S batt.
is there a new FW that would work really well with V3 SP 4.0T motor? base set-up would be greatly appreciated
currently running 508MOD FW but am having ESC thermal at end of 8 min run. If i tone down timing (DMTS) to get cozy temps after 8-min run, i feel its too slow down the straight.
