The Speed Passion Thread >
Like Tree57Likes
Old 02-18-2011 | 04:57 PM
  #6586
qcrc's Avatar
Originally Posted by ChefDementia
What functionality does the SP android app currently have?
I have not tried it yet but here is some info on it.
http://www.speedpassion.net/us/mobileapps.asp
qcrc is offline
Old 02-19-2011 | 03:07 AM
  #6587
Does someone might have a good starting setup for a V3 13,5 with the 101212 stock software for a short indoor track?
GerwinGood is offline
Old 02-19-2011 | 05:12 AM
  #6588
Here you go buddy.
http://www.speedpassion.net/en/escsetup.asp
kwiksi is offline
Old 02-19-2011 | 11:13 AM
  #6589
Hello guys,
does the new stock software
from january 2011 have more power than the old one?
another question:
how to get more power - increase or decrease #15 in the software
i have no chance against GM ESC with same Motor.
How you gear on a small carpet indoor track?
i had to gear 7,9 to get a chance but temp is very high
i think this is much to short isnt it
motor is lrp x11 13,5
please help me out tomorrow is race day :-)
my esc settings:
4/9
9/8
12/8
13/1
14/1
15/1
greetings
johan
Johanson132 is offline
Old 02-19-2011 | 11:42 AM
  #6590
charlie_b's Avatar
Super Moderator
Originally Posted by Johanson132
Hello guys,
another question:
my esc settings:
4/9
9/8
12/8
13/1
14/1
15/1
greetings
johan
With the new software you can not use max settings on the esc or it will bog down. Try this.
4/7
9/7
12/6
13/2
14/2
15/3
This should get u closer. As far as #15, if you read the SP site, all it does is retard timing on the bottom end to get punch. SO if your DDRS and AMTS is lower, you don't need to run your SC punch too high.
I highly recommend reading the SP site directions so you can have a better grasp on how to program/set up the ESC. There in no way for anyone to tell you exactly how to tune your esc because there are too many factors involved and we are not at your track to test. Again, read the instructions, then play with the settings. THe base settings i gave you should put you in the right direction. Good Luck.
charlie_b is offline
Old 02-19-2011 | 11:59 AM
  #6591
Mh strange to Run Lower settings
Ill give it a try
When its Not good ill go back to old Software.
Same there with to high settings ?
Tanks for your help.
Old 02-20-2011 | 03:57 AM
  #6592
cyclone speed's Avatar
Hello, im doing abit of shopping from abroad and I was wondering if the hobywing programming card would work on my SP GT2.0 LPF ?
cyclone speed is offline
Old 02-20-2011 | 04:55 AM
  #6593
RevMaxx's Avatar
is the speed passion site down?
i can't seem to access them a few minutes ago..
RevMaxx is offline
Old 02-20-2011 | 04:58 AM
  #6594
Seems OK to me.
Dave H is offline
Old 02-20-2011 | 06:13 AM
  #6595
charlie_b's Avatar
Super Moderator
Ill give it a try
...this software is much better/faster than the old ones...but ultimately it is up to you to run what ever you want.
Old 02-20-2011 | 08:45 AM
  #6596
charlie b, i got a new phone and lost your number. could you please give me a call?
ty, rich
gdcopbdcop is offline
Old 02-20-2011 | 01:47 PM
  #6597
thilo-alexander is offline
Old 02-20-2011 | 06:14 PM
  #6598
SCTom's Avatar
Can someone tell me how much timing and boost is in the 101212 stock software. I have found info. for the different HW software, but not SP.
Thanks, Tom.
SCTom is offline
Old 02-21-2011 | 07:36 AM
  #6599
ChefDementia's Avatar
Originally Posted by mr crum
well ur latest problem sounds like sensor wire and your earlier problem sounds like the software didnt get flashed to the esc twice it is recommended that u flash software twice to the esc
Tried a new sensor wire this weekend and the problem is still there.
ChefDementia is offline
Old 02-21-2011 | 07:51 AM
  #6600
charlie_b's Avatar
Super Moderator
ty, rich
Rich, sent u a text.
