The Speed Passion Thread
#6466
i have one for sale
Speed Passion Grand Turismo vers.1.1 brushless speedcontrol complete with everything. = make offer
#6467
Hello, I use v3.0 10.5t motor and esc GT2
this is my setup. and I use ratio of 5.2
at the end of the straight people who use another motor or other esc always reaches me. In the corners is more balanced.
what I'm missing?
this is the track = http://www.aarcdoabc.com.br/modules....showpage&pid=4
somebody can helpme?
what I'm missing?
Code:
SETUP: 1 - 1 2 - 1 3 - 4 4 - 7 5 - 4 6 - 1 7 - 2 8 - 1 9 - 5 10 - 2 12 - 9 13 - 2 14 - 1 15 - 1
#6468
Hi Shawn,
You should post a new thread with the name speed passion. This time we will abide by the rules of board. And i hope this would be more informative then the previous one.
#6471
Typed Version Correctly.
Guys Let's get back on track,
i see many asked and talked about software and typed 1224
Please correcting that the right version is V3.0_101224STOCK
V3.0 = is a Third Generation Software
Do not Compared it with
V2.0_101212STOCK
V2.0 = is a Previously Second Generation Software
That's all may come new updates but different Version Generation,
So please don't just type 4 digits "1224"
typed it completely ex : V3.0_101224STOCK or V3.0_110119STOCK or V2.0_101212STOCK
date version is (version Generation + 6 digit)
So we all know which version is to be discussed.
Thank's For attention.
V2.0_101212STOCK
#6474
V2.0_101212STOCK
V2.0_101212STOCK
#2...what is 1224stock? Where is it..?
#3 Again, you need to keep your eye open...this is Speed Passion thread, not HobbyWing thread....
#4...when ppl say 1212, everyone here know exactly what they are talking about, except you.....apparently.
#5...have you buy your Speed Passion ESC and upload the 1212 software and give that a try yet? Or you are still trying to find out more information before you are going to start thinking about buying SP products...? You have been asking tons of question for the past year and still have not tried any SP stuff, when are you going to start...? Until SP has the RPM log developed? Really...?
#6475
http://www.speedpassion.net/en/mobileapps.asp
http://www.speedpassion.net/edm.asp?...1102021424&r=0
Android Version
RC Car A1 HD
The Apps is for R/C car driver to record the important information such as Laps time,
motor model, Car model, ESC setting, Gear Ratio.
It almost includes all ESC setting forms for driver to record the ultimate lap time.
And then it has the share function for driver to share the best lap time to internet.
All drivers can immediately know the top driver's record.
p.s. This Apps only supports 480 x 800 or above screen resolution.
Android Version
RC Car A1 HD
#6476
what I'm missing?
what I'm missing?
Code:
Your #15 setting is incorrect for the application. You have a very sharp timing vs RPM curve, which will kill motor torque and make it run very hot. Also, the FDR you posted would be for a MONSTER sized track. To compare, I was running 7.4FDR on a 150ft straight.
Here are my 10.5 settings for a large track: http://www.speedpassion.net/uploadfi...egenAsphal.pdf
Pic of Track (full straight is 220ft):
http://maps.google.com/maps?f=q&sour...02064&t=h&z=20
#6477
LPF 2.0 is slow
My LPF 2.0 ESC is acting strange.
When i first turn it on and pull the trigger the first time on the track it RIPS!, front tires off the ground and all.
After that its like the battery is dead. It runs ok but lacks speed, won't get over the triple and seems like timing/boost is gone like i unplugged the sensor cable.
Every once in a while the boost will kick in and send me rocketing down the track.
I have done a bunch of things to it to eliminate outside problems.
Changed sensor wire from a vehicle that was working correctly
Changed motor
Adjusted settings moving boost and timing up and down.
I eliminated the LVC to none in the ESC.
I reset the ESC to the Controller after every different setting.
Any Tips on what to do next?
Changed motor
#6478
Changed motor
Changed motor
#6480
How do the 1cell v3 motors compare to a ballistic? where do you start with timming and gear. Thinking about trying this in oval.
