The Speed Passion Thread >
Like Tree57Likes
Old 10-22-2010, 07:37 AM
  #5836
Solara;
you have a PM.
Bob Oaks
bob o is offline
Old 10-22-2010, 11:15 AM
  #5837
Photocycler's Avatar
Trader Rating: 36 (100%+)
Can anyone recommend a good heatsink /fan for a SP 10.5 Brushless..this is going in a WGT car
Photocycler is offline
Old 10-22-2010, 04:22 PM
  #5838
xrayal's Avatar
running 528 on gt2.0 pro, v3 13.5 on a short tight indoor carpet track with a 22m straight. 66feet.
where should i set the timing to on the motor? max acceleration is more important than terminal velocity. many thanks.
xrayal is offline
  #5839
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
is it getting that hot usually you dont need heat sink/fan
TRXRACER99 is offline
Old 10-23-2010, 12:17 AM
  #5840
sosidge's Avatar
Leave the timing in the middle of the slot. Let the ESC software sort out the timing.
sosidge is offline
Old 10-23-2010, 01:07 AM
  #5841
I haven't run it yet just want to be cautious. I will be running a 10.5 with boot in a pan car
what temps should I be looking for
Old 10-23-2010, 02:36 AM
  #5842
xrayal's Avatar
[QUOTE=sosidge;8110804]Leave the timing in the middle of the slot. Let the ESC software sort out the timing.[/QU
thanks dude
xrayal is offline
Old 10-23-2010, 03:50 AM
  #5843
peter george's Avatar
Trader Rating: 377 (100%+)
Ever have your GT 2.0 start 2 act like the lipo is dead after only a minute racing? It literaly cuts off like its ''thermoing''.I have tried the sensor wire and motor but it still does that problem.Could it be the capacitor? and or the software? thanks.
peter george is offline
Old 10-23-2010, 04:00 AM
  #5844
xrayal's Avatar
id try another lipo, check your lipo cut off. try at least 3 sensor wires and check your soldering. when it cuts out whats your motor/speedo temps. have you changed your gearing?
xrayal is offline
Old 10-23-2010, 07:27 AM
  #5845
TRXRACER99's Avatar
What motor speedo combo are you using should be looking at around 160-170 or lower if possible but that is the safe zone. you shouldn't need a heatsink/fan plus pan cars usually dont react well with a heatsink /fan in the rear pod so just a few things to watch.
Old 10-23-2010, 05:44 PM
  #5846
The issue starts after almost the second lap, and the temp are not hot ,just warm.Could it be my computer? I will try to change another couple of sensor wires,but when it did the problem...I put the motor from my car with the lrp old spere -same thing.Thanks for the input,I will try to download the set up again and see what happens.Is this anything that any body here has ever experienced? Also even if some other car runs close and hits me I experience some loss of power...?
Old 10-23-2010, 05:49 PM
  #5847
Joel Lagace's Avatar
I hope there is an android app for the speedpassions! please... android is the future.
Joel Lagace is offline
Old 10-23-2010, 06:43 PM
  #5848
RCHR Racer's Avatar
Default 528 Mod firmware
Solara,
Hi, Can the 528 Mod firmware be used in a GT2.0pro ? Is there an advantage to this speedo over my GT2.1pro with an 8.5 V3 and/or 7.5 V3 for offroad, your opinion/knowledge base?
Thanks a billion !
Brandon
RCHR Racer is offline
Old 10-23-2010, 08:25 PM
  #5849
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RCHR Racer
Solara,
Thanks a billion !
Brandon
In onroad tc, I couldn't feel much of a difference between 528MOD and 205_MOD in my Gt2.0 Pro. This was on a medium sized track.
defcone is offline
Old 10-23-2010, 08:39 PM
  #5850
fjm9898's Avatar
bring back the 2.1ex!
fjm9898 is offline
