The Speed Passion Thread
#406
RedRC says there's some being tested at ETS with a unique new wiring system. I wonder if this pic is what they mean?
http://ets.redrc.net/wp-content/gall...luingtires.jpg
#407
1 cell lipo set up for 12r5
i switched to a 1 cell lipo set up and my car is wanting to spin coming in and out of corners...i turned the punch down a little and it still wants to wash out in the rear a little..here is my setup help me out...
.020 front springs
neg 1 camber
10 degree upper arm mount
6.15 caster
gold side spring
copper middle spring with 40wt oil center shock
side shock 30wt oil
Pink rear tires
purple fronts..
help me out someone..the car is spinning ...not as much as it was before I untweaked it...i cannot drive it aggressive coming in and out of corners..
.020 front springs
neg 1 camber
6.15 caster
gold side spring
side shock 30wt oil
Pink rear tires
purple fronts..
#408
abailey21. you have a email.
#410
#411
#412
speedpassion gt2.0 usb
Adam Bailey
why Speedpassion does not have like this
castle creation
it seem tobe a lot more simpler, to allow us quick configure at any computer.
castle creation
#413
Gilles is only using SP motors while Mark and Victor are using the GT 2.0
#414
and why hoax usb plug logo
if not like this
castle did not lie about usb.
if not like this
#417
http://www.speedpassion.net/product.php?lang=&c=17
#418
but this GT2.0 only use the same wire for receiver,
that would be annoying must plug and unplug from receiver or esc ?
and why not add the simple usb wire for cheaper one as support option too?
#419
#420
Neutral range
What does neutral range do? I always set mine at 6%. In what condition should i change its setting?
