Idea to Use brushed motor dyno for brushless
Can anyone out there tell me if this would work please.
1. Conected the power wire to a brushless esc instead of a brushed motor.
2. Fit a reciever pack to a reciever.
3. Plug brushless esc into reciever
4. Keep full throttle held on Transmitter
5. Start motor dyno test.
Crazy Idea I know, but I can't see a technical reason why it wouldn't work.
If it works it could be used to compare esc effeciency as well as motors.
I'm thinking there must be a reason it wouldn't work or it would have been done before.
http://teamnovak.com/products/data_l...try/index.html
The brushless RPM sensor (measured at the motor sensors it appears) combined with the current sensor might be a decent start. You could simulate load with a prop or something I guess.
I'm wondering if Novak's Sentry can be used to come up with some kind of crude dyno.
Although I don't have a Sentry I do have a very expensive robbitonic dyno that I have not even tried yet. If I could use it to test brushless I'd be very happy. Don't want to break anything trying it
It works. Fairly common among some of the oval guys who've been running the Brushless Racing League.
get rid of the RX and TX and use a servo testor.
No luck so far.
Hooked up gtb with 4 cell receiver pack.
The gtb seems to be getting confused when you apply the throttle and there is no main input voltage.
Miller tyme, do you know what esc's they have used?
doesn't sombody make a magnet strengh tester specialized for brushless rotors?
http://cgi.ebay.co.uk/Gauss-Meter-Ma...sid=p1638.m122
Were using the CE Turbo Dyno - output hooked to the input of the ESC (using both GTB and LRP) with the ESC switch on, when the dyno is started it puts a set voltage to the ESC and with the radio throtte held full, the motor spins.
Check LEFTHANDER-RC.com under brushless
and i am selling my fantom.....
anyone interested????
