Old 01-19-2008, 10:31 AM   #1
JevUK's Avatar
Default Idea to Use brushed motor dyno for brushless
Can anyone out there tell me if this would work please.
1. Conected the power wire to a brushless esc instead of a brushed motor.
2. Fit a reciever pack to a reciever.
3. Plug brushless esc into reciever
4. Keep full throttle held on Transmitter
5. Start motor dyno test.
Crazy Idea I know, but I can't see a technical reason why it wouldn't work.
If it works it could be used to compare esc effeciency as well as motors.
I'm thinking there must be a reason it wouldn't work or it would have been done before.
JevUK is offline   Reply With Quote
Old 01-19-2008, 10:54 AM   #2
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm wondering if Novak's Sentry can be used to come up with some kind of crude dyno.
http://teamnovak.com/products/data_l...try/index.html
The brushless RPM sensor (measured at the motor sensors it appears) combined with the current sensor might be a decent start. You could simulate load with a prop or something I guess.
syndr0me is offline   Reply With Quote
Old 01-19-2008, 11:45 AM   #3
JevUK's Avatar
Sounds possible.
Although I don't have a Sentry I do have a very expensive robbitonic dyno that I have not even tried yet. If I could use it to test brushless I'd be very happy. Don't want to break anything trying it
Old 01-19-2008, 12:01 PM   #4
RussB's Avatar
Send a message via MSN to RussB
it sounds like the sentry has the appropriate accelerometers to be able to calculate power output based on the telemetry.
RussB is offline   Reply With Quote
Old 01-19-2008, 01:53 PM   #5
miller tyme's Avatar
It works. Fairly common among some of the oval guys who've been running the Brushless Racing League.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is online now   Reply With Quote
Old 01-19-2008, 01:55 PM   #6
trailranger's Avatar
get rid of the RX and TX and use a servo testor.
trailranger is offline   Reply With Quote
Old 01-19-2008, 01:57 PM   #7
I'm thinking an extra rx with the failsafe set to full throttle
Ken Miller
Old 01-19-2008, 05:25 PM   #8
JevUK's Avatar
No luck so far.
Hooked up gtb with 4 cell receiver pack.
The gtb seems to be getting confused when you apply the throttle and there is no main input voltage.
Miller tyme, do you know what esc's they have used?
Old 01-19-2008, 05:34 PM   #9
ottoman's Avatar
R/C Tech Charter Subscriber
Most guys use the CE turbo dyno for brushless testing and use the B/L esc to run the motor.
ottoman is offline   Reply With Quote
Old 01-19-2008, 05:42 PM   #10
CHRIS CHAVEZ's Avatar
doesn't sombody make a magnet strengh tester specialized for brushless rotors?
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 01-19-2008, 05:47 PM   #11
JevUK's Avatar
All I've got is a robotrinic and novak gtb. Do you know what esc they used?
It doesn't need to be rc specific
http://cgi.ebay.co.uk/Gauss-Meter-Ma...sid=p1638.m122
Old 01-19-2008, 05:54 PM   #12
No luck so far.
Were using the CE Turbo Dyno - output hooked to the input of the ESC (using both GTB and LRP) with the ESC switch on, when the dyno is started it puts a set voltage to the ESC and with the radio throtte held full, the motor spins.
Check LEFTHANDER-RC.com under brushless
Ken Miller
Old 01-19-2008, 07:02 PM   #13
RussB's Avatar
that's a darn good idea... and it makes sense since brushless is more of a system than brushed.
Old 01-19-2008, 07:25 PM   #14
Jmccormick's Avatar
Zubak makes one called the Zubak speed meter.....
www.speedjuice.com
Jmccormick is offline   Reply With Quote
Old 01-19-2008, 11:26 PM   #15
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
and i am selling my fantom.....
anyone interested????
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
I need a 1/18 Brushed/Brushless Motor w/ESC Combo..Need ASAP smarking1212 Micro and Mini Scales 4 07-19-2008 07:55 PM
FS: Novak GTX esc, brushed motors, comm lathe, motor dyno mike williams R/C Items: For Sale/Trade 12 03-17-2008 04:26 PM
LRP 80500 sphere brushed/brushless with motor Tmachine R/C Items: For Sale/Trade 3 02-18-2008 11:59 PM
Motor: Brushed ..T = Brushless ....KV ? skyblueblue Singapore R/C Racers 20 06-12-2007 09:54 AM
WTB; Brushless or Brushed motor setup. NitroMaxx3.3 R/C Items: Wanted to Buy 1 09-09-2006 11:42 PM
