New Yokomo TC, the BD-5 >
Old 01-18-2012, 07:37 PM
  #3376
Trader Rating: 14 (100%+)
Originally Posted by Hugh Jazz
Some o e mentioned that you have to file the back of c hub to get full travel
Originally Posted by DirtyDog3375
In the amended instructions (incl. with the new DCJ cvds) it states you must chamfer the inside edges of the c-hub.
Once done, you should be able to get full lock and the DCJ wont touch the c-hub at full lock.
Also, make sure you take apart the DCJ (as they are assembled) and grease up using Yokomo High Protect Grease or similar and loctite the grub screws when reassembling.
HTH.
Leonard.
thanks guys! I asked Hobby Haven to ship the kit without the instructions so I won't have too many problems with duties. In any case, thanks for explaining, I rebuilt the knuckles like 5 times each side trying to figure out what i did wrong! Will be doing a test run of my car today, hope all goes well!
Thanks again!
mikeygar is offline
Old 01-22-2012, 12:42 AM
  #3377
Originally Posted by SammyZ
i ordered it...ill let you guys know what i think of it compared to the OEM chassis
Was going to order a new worlds chassis but now thinking of this instead,feedback would be good.
retro_ryan is offline
Old 01-22-2012, 05:20 AM
  #3378
fpart's Avatar
Trader Rating: 41 (100%+)
I just finished putting together my new WXC kit. It was awesome. The DCJ's look good. I thought I was upset when the rear cvd seemed to be just the steel ones. But it looks like it may be made out of some sort of spring steel. I think it is a must for BD5 owners also if it is truly spring steel.
I also noticed that it seems Volker seems to be using the same chassis at teh carpet ets race in Italy this weekend. I thought this chassis was really for low grip tracks. Can anyone confirm?
fpart is offline
Old 01-22-2012, 09:12 AM
  #3379
kschu's Avatar
Trader Rating: 16 (100%+)
wx lowerdeck is more suitable for low traction track.
kschu is offline
Old 01-22-2012, 01:11 PM
  #3380
SammyZ's Avatar
Trader Rating: 138 (100%+)
the rear CVD set is the original old yokomo steel.
SammyZ is offline
Old 01-24-2012, 09:33 AM
  #3381
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Who has the GT500-R kits in stock?
http://www.teamyokomo.com/gt/lineup/gt5_r/gt5_r.html
RAL is offline
Old 01-26-2012, 06:48 PM
  #3382
Just broke one of my DCJ's last night. anyone had better luck? They were well lubricated and were thread locked tight. Running 13.5 with boost, spool up front and the 2 halves separated destroying my c-hub and my knuckle. No hard crashes...
Honestly am quite disappointed with them, it's the 2nd time I run my WXi and this has to happen just before TITC.
Any good alternatives to the Yokomo DCJ's?
mikeygar is offline
Old 01-26-2012, 07:01 PM
  #3383
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Ive been using the version 2 Spec-R DCJ'S and they have been great so far
A Ilievski is offline
Old 01-27-2012, 12:00 AM
  #3384
agree. have also been running the version 2 of the specr for some races now in modified 4.5T. they start being a little bit sloppy now after some 40 batteries run with them .so far no problem at all.
vitomon is offline
Old 01-27-2012, 12:45 AM
  #3385
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Not sure what happened. But I have had the Yokomo DCJ for awhile now - over 30 runs worth with no wear or damage in sight (running 4.5t). I rebuild mine every 3-5 runs. Hope you get it sorted soon.
DirtyDog3375 is offline
Old 01-27-2012, 01:56 AM
  #3386
maybe I should give them a look. Will order a set. Do they use the same bearings the Yok DCJ's use?
I run around ten packs per track day, so 2 days worth of track days = 20 runs without a rebuild... DOH! Took it for granted that you need to rebuild these. Should once per track day be enough? Will order another set and see how it goes
mikeygar is offline
Old 01-30-2012, 11:02 AM
  #3387
Trader Rating: 38 (95%+)
just sold my s411, and looking at getting the bd5wxc kit, is this the newest kit, and comes with the djc, and a high grip chassis correct, also how are parts to get in north america, and is this car any better then an xray2012 or the s411, anyone run these cars and can compare thanks any and all info would be great thanks
zaraz is offline
Old 01-30-2012, 10:36 PM
  #3388
RAL
RAL's Avatar
Driftspeed carries Yokomo parts in the US. He'll be taking pre-orders for kits as well...
http://www.driftspeed.com/index.php?...s&news_id=1108
RAL is offline
Old 01-30-2012, 11:44 PM
  #3389
kschu's Avatar
is the DCJ hitting the c-hub when full lock steering ?
kschu is offline
Old 01-30-2012, 11:46 PM
  #3390
kschu's Avatar
u running on carpet or asphalt?
kschu is offline
