Like Tree3Likes
Tamiya TRF415
Old 05-26-2006, 03:25 AM
  #14281
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
ok, thank you very much. The belt is a little too close for comfort to the antenna screw, lol.
HotrodHopkins is offline
Old 05-26-2006, 05:18 AM
  #14282
Leester's Avatar
Trader Rating: 23 (96%+)
Originally Posted by Eirik
The best and cheapest part you can get for the MSX to make it lighter and more responsive is a Protoform Mazda 6 Light Weight bodyshell
anything else that would be good lightweight after market parts?
Leester is offline
Old 05-26-2006, 05:38 AM
  #14283
Burlap's Avatar
A dremel
Remember, if you are racing this car at competitions, you have to at least 1500gms.
Burlap is offline
Old 05-26-2006, 08:34 AM
  #14284
Been away from racing for alittle while , how much better is the MSX over the normal 415 ?
weekendracer_uk is offline
Old 05-26-2006, 08:43 AM
  #14285
dynoman007's Avatar
Talking 415
the msx is a ton easier to work on that is the largest change ...
dynoman007 is offline
Old 05-26-2006, 09:28 AM
  #14286
R/C Tech Elite Member
JayL's Avatar
lee:
get this:
Tamiya USA TA05 Stabilizer Set (F & R) Black
Part #: 49383
then you can tune your car with the sways front and rear, very nice!
JayL is offline
Old 05-26-2006, 09:37 AM
  #14287
TryHard's Avatar
it's not the bulk heads (lower part) it's the top part where the shock tower and the top part connect with the lower bulk heads. When i try to screw in the top part it tips to one side and then when i take the crews out to try it again i try to srew in the other side it tips to the other side. i'm not using the right words to discribe this but. i can't screw on the top bulkhead that connects with the lower bulk head with the one waypuley inside. i gt the pulley to fit inside the bulkhead but it's screwing it in that's giving me problems. What can i do?
-lee
Hmm... sounds like the bearing holders aren't located properly. If, like you say, you can get the parts fitted into the lower bulkheads, then it sounds like the bearing holder notches aren't located properly, keeping you from tightening down the upper bulkheads.
Any chance of pictures showning the problem? Should be able to help more with them.
HiH
Ed
TryHard is offline
Old 05-26-2006, 09:39 AM
  #14288
TryHard's Avatar
well looks like a shocking turn of events has occured.
I acataully got the bulk heads on the front to work after loosing up the shock tower and i got it to fit just right i put the diff in and that worked as well.
Thank you for everything but i'm not done yet i still have a few questions to ask you.
What are some good aftermarket hop up options that i can put on my 415 that reduces weight? waht type of aftermarket parts can i buy that will enhance the cornering speed of the car and make it more snappy through the infield
in other words. what are the best aftermarket upgrade parts for the Tamiya 415MSX? any suggestions?
-Lee
Doh! Didn't read this... good news though
TryHard is offline
Old 05-26-2006, 11:38 AM
  #14289
415 old supension is a lot better suited for carpet racing. Than the current lw supension. Still wait for the evo5 lw supension to become available for the 415. the new supension should make it handle even better on carpet that the old 415 supension.
Smoking motor.. is offline
Old 05-26-2006, 01:45 PM
  #14290
Leester's Avatar
Originally Posted by tony q
i saw the picture at world's warm-up marc rheinard was using it, but if you are not using it. what is your final ratio? is it still the same 2.187.
i really don't know. does anybody know waht the final drive ratio is with the 415MSX with TA05 diff pullys but with 415 center pullys?
Do i really need to have teh TA05 center pullys on the 415? or can i just run with out them?
-Lee
Leester is offline
Old 05-26-2006, 01:47 PM
  #14291
Leester's Avatar
Originally Posted by Burlap
A dremel
I know. But waht would be some good after marketparts that would lighten it up but keep it in the 1500g range?
Leester is offline
Old 05-26-2006, 02:16 PM
  #14292
It's already underweight and there are no hopup that will make a big enough differance to lighten it.
But you can use Titiainium screws to save 100grams remember to use a good driver and blue thread lock them into any alu part.
Just use change the diff balls to ceramic for less maitenace and keeps the the diff running smooth as butter.
Replace the turnbuckle with the ti versions as you will get annoyed when you bend one of the alu ones at the slightest touch.
If running on carpet run the older 415 supension or convert it to run hpi supension and 4mm chassis for running foam tyres,
Old 05-26-2006, 02:23 PM
  #14293
JayL's Avatar
the stock ta-05 center pulleys are the same tooth count as the stock 415msx center pulley(s)...just the front one-way/spool and rear diff pulleys are uh diff..
JayL is offline
Old 05-26-2006, 09:09 PM
  #14294
Leester's Avatar
I'm running rubber on carpet would HPI arms make a big diffrence with rubber tires? and what will it do? And what HPI arms for which Hpi car are you talking about and where can i order them?
Leester is offline
Old 05-26-2006, 09:51 PM
  #14295
drew85's Avatar
I think its the cyclone/pro4. arms all the other cars are way diffrent.
drew85 is offline
