Tamiya TRF415
Originally Posted by Rick Draper
They are a little short when running D/A suspension block up front. I have ordered some 48mm ones from the tamiya F1 UJ kit.
and are there no problems with D/D suspension block up front???
Originally Posted by GT Racer
You need to get some different springs & shock oil. Also, the new MSX kit come with only 1 piece of yellow (front) and 1 piece of red (rear) sway bar, you may want to get the rest to setup according to different track conditions. If you're running spool, stock up some belts.
Hope this helps.
Hope this helps.
New stick pack chassis with new upper deck.
is running a front spool actually better than running a front oneway on tight high grip tracks?
Originally Posted by viper1
I am sure what u saw was the same car they had at the tokyo hobby show. It was a car that maizumi built specifically for the show. They did say then that it will not be out for the near future.
the link to it is in the 05 Thread but a few pages back.
the TA05MS debuted at the Tamiya Fair in Shizuoka. *(i was at both events)
I've also heard the 05MS isn't in the near future. Maybe an R version first.
Originally Posted by TENCHO
I went to the tokyo hobby show, and there was no TA05MS....just a refine2.
I might be wrong though so i do hope u are right and the TA05 MS is on the way.
Cheers
Stick pack lower deck!!
stick pack chassis......BOO!
TRF TA05MS
The photo of that TA05 MS or Maizumi special as it was called was at the tokyo show. Let me do a little digging. I might still have the pic.....I hope u had a great time in shizuka.
Cheers
Cheers
Does the MSX has a one way or locked middle pulleys? Thanks.
Guys if yo wanna talk of the TA05 why don't you do so in the TA05 thread ? I personally don't care if there's a TA05 MS version, it'll never be as good as the 415, you can trust me on that, i've got a TA05 chassis on my desk right now.
New 415 parts soon
53891 5x1.9mm Bearing Spacer 4pcs - For Reversible Suspension
53890 Swing Shaft Protector - 4pcs
53889 Alum Diff Joint Set - TRF415
53873 Setting Spacer Set - Carbon Damper Stay
49382 On Road Tuned Spring Set - White
