Like Tree3Likes
Tamiya TRF415
Old 06-15-2005, 08:01 AM
  #9166
V12
V12's Avatar
Itīs #79189
V12 is offline
Old 06-15-2005, 05:52 PM
  #9167
Bad Boys Racing's Avatar
Originally Posted by F. Alonso
Mine are just a rectangular shape as that's what my chassis was like anyway! Are yours like circles??
I Kid... I kid!
mine angle in on the edges
Bad Boys Racing is offline
Old 06-18-2005, 09:18 AM
  #9168
ttso's Avatar
Default Upgrade to LW reversible suspension
After a major crash today, I got my old suspension right front end totally smashed. Since my LHS got no EVO3/414/415 old suspension parts, now I forced to upgrade with LW reversible suspension for parts availiability.
I know #49346 TRF415 LW Suspension Set (Reversible) will do the job but it seems hard to find. However, the TB02/TA04 one, #53794 Reversible LW Susp. Set (TB-02 & TA04), seems much more easy to find. However I check the spec seems #53794 has everything I need to upgrade 415 with LW suspension except the 46mm swing shaft. If I can't find #49346 but have to go with #53794, is that right I only need 4 more 46mm swing shaft to make it work? Or I missed something else?
Thanks lots.
ttso is offline
Old 06-18-2005, 10:21 AM
  #9169
dsrbltoys's Avatar
I know the shim count is also different (no big deal). Another thing is the length of the tie / camber links I believe are different. I have the 415 set on my ta04. I have had it also on a tb02. The nice thing about the correct kit is you get settings for the car you put it on, Thought those are easily found online now.
dsrbltoys is offline
Old 06-19-2005, 07:39 AM
  #9170
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Anyplace have the 415 Front Suspension Mount D that goes over the front belt in stock. Part # TAM51064. Tried Speedtech but it shows out of stock. Mine was bent in a nasty wreck and I'm in need of another before I can race again.
Brian
wyd is offline
Old 06-19-2005, 08:07 AM
  #9171
wyd: try Ultimate Hobbies...they might have it in stock.
atomic80 is offline
Old 06-19-2005, 12:09 PM
  #9172
wyd
Tech Legend
wyd's Avatar
Thanks I will look their.
Brian
wyd is offline
Old 06-19-2005, 05:12 PM
  #9173
C_O_jones's Avatar
The susp block is made of pretty soft material, Ive staightend mine lots of times, comes with my driving style. haha.
Small hammer, flat suface and a straight edge, with light taps it will staighten out
Fred
C_O_jones is offline
Old 06-19-2005, 05:16 PM
  #9174
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Brian
Brian PM me... I can help ..
-Dave
JDM_DOHC_SiR is offline
Old 06-19-2005, 06:09 PM
  #9175
Brian
In a hurry you can use a rear d mount, turn it upside down and use shims to raise it to the corret height.
Besercoe is offline
Old 06-19-2005, 07:03 PM
  #9176
Trader Rating: 79 (99%+)
Default I need help
Does anyone have a part # 49308, I am looking for these and no one seems to have them. They are the aluminum shock tops, with mounts in blue. Can someone please help?
Raul Garcia is offline
Old 06-19-2005, 07:07 PM
  #9177
Default part needed
sorry double post.
Old 06-19-2005, 11:14 PM
  #9178
Can someone please explain to me the pros and cons of narrow suspenion (ie xa,xb,xc etc... blocks)
Dragonfire is offline
Old 06-20-2005, 02:13 AM
  #9179
F. Alonso's Avatar
I have a MASSIVE problem...
In the process of rebuilding my car and my grub screws holding all the parts onto the center shaft (for spur gears and pulleys) seem to be ridiculously tight. I cannot get them off no matter what I try (that's 2 hudy profitool tips later ) so if anybody has any suggestions of what I can do to get this apart, could you please let me know. I'm desperate!!!!!
F. Alonso is offline
Old 06-20-2005, 03:20 AM
  #9180
MrTamiya's Avatar
I had that problem on a pinion once, so I tried a portable butane soldering iron with blow torch attachment, gently heated the area around the grub screw to soften the alloy slightly, use this as a last resort though, it may weaken the metal if it gets too hot. Don't burn the beutiful blue alloy!
MrTamiya is offline
