Tamiya TRF415
#6348
try r10 they are located close to the Tamiya factory in japan, and can get you anything tamiya, even if its not listed on their stock list, just drop Nao an email
http://www.rainbowten.co.jp/english/
#6350
i dont think that'd work (or atleast i cant see how), part # 4034010 is the graphite plate which the flanged bearings mount into which connects both steering arms together and mounts the inboard ball connectors of the steering links...
#6351
Re: I need help
Originally posted by dawgmeat
I've been seaching the whole web but can't find anyone who sells the graphite steering linkage for the 415 #4034010
I've tried speedtech, victor, stella and towerhobies
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5938310942
#6352
Re: 415 vs 415ms parts
does the Ms shock towers and bulkheads sit lower than the stock towers and bulkhead.
#6353
Re: Re: 415 vs 415ms parts
Originally posted by michel
The bulkheads sit lower also, beacause of the 2.6mm chassis
Depends where you take the reference from.. from the top of the chassis plate, no they are the same (baring the smaller height of the tower itself).
from the road, yes, as the thinner chassis is taken into account.
#6355
The only difference between the bulkheads are the mounts for the chasis are thinner so they don't rub on the arms. If you put the lightweight suspension on the 415 you had to cut the arms so they didn't rub. Plus the have the letters MS stamped on the side.
#6356
Diff. Ball Size
Can anybody tell me the size of the diff. balls for the 415? I'm looking to upgrade to ceramic and need to know the size. Thanks.
#6357
3MM
#6359
Ceramic diff bearings feel really good when first built. But unless you have a way of sealing the dirt out of the diff pulley, and have a ceramic thrust bearing and a way of keeping dirt out of that as well, you may be disappointed with how long they last. Lately, I've been using the "lightweight" balls from Tamiya...They only cost a few bucks and you get 20 balls. But when a big race comes up...ya, I'll be bustin out the good stuff.
#6360
i am using the acer ceramic diff balls and they are really smooth the only thing is there is no ceramic thrust bearing for the tamiya cars which kind of sucks .
