Tamiya TRF415
#5117
Looks like I'm going TRF too. The 415MS is a sweet looking car from the display models at Shizuoka. I'm looking at the Evo IV as well. It's good to have two cars for different conditions.
#5118
R/C Tech Elite Member
What motors are run in GT-1?
#5120
Originally posted by Randy Caster
I just wanna do what you accomplished this year and make it to Japan.
at the Nats, they specified a new 23T motor, that you had to get from them... at 25 ea, as i remember. 2 motor maximum!
#5129
Originally posted by Hebiki
sorry blake. the other option you have is to take an evoIII A block and flip it upside down, use some spacers to screw it in. works the same thats what i did before i got my A bridge block. ghetto but effective.
You can also order a 414M2 suspension block A and do some minor dremeling where it interferes with the belt. There is more material in the 414 blocks and they are less likely to bend. You will also need to shim it exactly 1 mm above the chassis.
The 414 blocks are the lowest.
The 415 blocks are 1mm higher above the chassis.
The Evo3/4 blocks are 2mm higher than the 414 blocks.
Get one here:
http://64.70.208.72/speedtechrc/237.html
#5130
Originally posted by Blakesrc
Hey Randy,
I just called Tamiya and they wont have a front bridge A block in for at least 8 weeks I was told! That is the part i need the most, any more sources?
Thanks,
Blake
Hey Randy,
Thanks,
Blake
-Dave
