Like Tree3Likes
Tamiya TRF415
Old 02-21-2009, 03:42 PM
  #20236
TryHard's Avatar
Originally Posted by Skitee
TryHard do you know if it's possible to run the 37tooth diff pulleys and 18tooth centre pulleys on the 415, if it is indeed possible what belts would you need to make it work?
http://www.thard.co.uk/415/tips/18tpulleys.html
Then just use the 37t pulleys on the car as well, you'll need to run the belts a little looser then with the 36's, but that it.
HiH
Ed
TryHard is offline
Old 02-21-2009, 03:47 PM
  #20237
TryHard's Avatar
Originally Posted by r_s
416's front upright uses 1050 bearing, MSX's uses 950.
if you want to use 416's front upright, u must also change the bearings and C-Hub to 416 version. CMIIW.
but i don't know the swing shaft, whether it still can use the 46mm swing shaft or must change to 44mm (416 version).
Actually, the 415 C-hub will fit with the 416 steering block... I ran that combo on my 416 when I first had it after ripping through the (rather fragile) carbon c-hubs....
Otherwise, yup, your correct, the bearings need changing to 1050's, as do the axles (different bearing spacing).
HiH
Ed
TryHard is offline
Old 02-21-2009, 03:51 PM
  #20238
TryHard's Avatar
Originally Posted by sidecarphil1
is there a stronger lower arm for the 415 ??
they seem brittle to me
i'm new to touring car racing (come from M-03 racing)
and i'm trying to learn to drive a TRF415MSXX MRE indoor but as soon as i make a small mistake i break the front suspension arm on the barrier !!
getting a little disgruntled with it !!!
Really??? I've never found the arms to be brittle at all... I think I've only broken 3 or 4 in 5years or so of racing tamiyas! I can't recall the last time I broken an arm on my 416 (uses the same suspension).
Other parts in teh steering I've broken, but otherwise the suspension is pretty damm robust.. and I've had some big hits (flat out into the barrier at WLRC being one).
Is it hard corners on your track? I know this sounds silly (and far be it from me to tell people how to drive), but maybe try dialing in some more understeer into the car to help it push wide of the apexs... at least till you get used to driving a TC.
HiH
Ed
TryHard is offline
Old 02-22-2009, 01:44 AM
  #20239
my problem on our track is the fast left after the back straight i just cant get it right and i either run wide with too much speed and hit the outer barrier breaking the right lower arm !!
or i turn in early hitting the inner barrier breaking the left front arm !!
i have broken 7 in the last 3 to 4 weeks GRRRR
maybe the 10.5 turn brushless and TC spec speedo is just too quick for me
sidecarphil1 is offline
Old 02-22-2009, 10:41 PM
  #20240
Ricky/C's Avatar
Hi guys
What difference does it make if you change the pulleys to lower the internal gear ratio? I'm using my TRF in stock racing and any advantage I can get out of this will be great!
What pulleys and belts will I need to get the lowest IR then? Thanks
Ricky/C is offline
Old 02-22-2009, 11:08 PM
  #20241
Skitee's Avatar
HiH
Ed
Thanks Ed, I just wasn't sure if the belts you had listed would be long enough with the extra tooth on the pulleys.
Skitee is offline
Old 02-22-2009, 11:16 PM
  #20242
Skitee's Avatar
Thumbs up
Originally Posted by Ricky/C
Hi guys
Ricky go to this link it has the part numbers for the belts
Ricky firstly it drops the internal ratio to 2.055 which lets you get to the bigger rollouts for silver cans without having to use the biggest fly wheel sized pinion you can find and so the motor has less rotational mass that has to be spooled up.
Maybe TryHard can tell us if there's an advantage to running a lower IR, so if you have 2 identical cars but one has a IR of 2.250 and the other has an IR of 2.055 and both geared to rollout at at 42mm. Would the car with the lower IR have an advantage of any kind?
Skitee is offline
Old 02-22-2009, 11:26 PM
  #20243
Ricky/C's Avatar
Cool thanks Skitee, you answerd my pm aswell
Ricky/C is offline
Old 02-23-2009, 10:31 AM
  #20244
Ricky/C's Avatar
I phoned our local Xray suppliers for the rear belt needed for the mod and they dont have
Ricky/C is offline
Old 02-25-2009, 08:39 AM
  #20245
Ricky/C's Avatar
COLOR="Blue"]Maybe TryHard can tell us if there's an advantage to running a lower IR, so if you have 2 identical cars but one has a IR of 2.250 and the other has an IR of 2.055 and both geared to rollout at at 42mm. Would the car with the lower IR have an advantage of any kind?[/COLOR]
Can someone please answer us on this??? I'm running my TRF with a stock Johnson 540 and I need the best setup please help Ed
Ricky/C is offline
Old 02-25-2009, 09:28 AM
  #20246
R/C Tech Elite Member
JayL's Avatar
Originally Posted by STLNLST
Everything showed up today. Looks like all I have to do is put things together. Next weekend looks like it's going to be fun.
yeah! pretty blue parts
I'm planning to start running mod this summer
What's a good fitting lipo?
JayL is offline
Old 02-25-2009, 09:39 AM
  #20247
Ricky/C's Avatar
Orion Race spec lipos fit after a minor mod to the rear bulkhead
Ricky/C is offline
Old 02-25-2009, 09:45 AM
  #20248
STLNLST's Avatar
Trader Rating: 32 (100%+)
I think the SMC 4000 may fit under the low bulk heads. I'm running the Orion 3800 but I had to mill the bulk head slightly to get it to fit. There are lipo tray's that push the battery out a bit so running bigger batteries should be fine. Dujuan bought the tray from Stomers and he seems to like the fit. Once I see how it looks in person I may go and get it. No mod for me. I'm sticking with 13.5 for now. That's what I'm running for the Reedy this time around.
STLNLST is offline
Old 02-25-2009, 10:15 AM
  #20249
Trader Rating: 19 (100%+)
Really? Bwaahahahahahahaaaaa.....sucka! ITS ON!!!!!!
Advil is offline
Old 02-25-2009, 10:36 AM
  #20250
STLNLST's Avatar
You're on the HB C team You might get lucky and get put into the same qualifying heat during a club race. Be happy with that I'll call you later on after I stop laughing from what I just typed
STLNLST is offline
