Tamiya TRF415
I guess they have it in store because they have the actual picture.
http://shopping.rcmodel.hk/product_i...oducts_id=9439
See for yourself.
See for yourself.
What Parts ahould I stock up on>>>?
I'm looking to purchase a new 415 MSX MRE. I'm wondering what parts are most prone to breakage on the car - and what I should stock up on?
Arms?
C-Hubs?
Steering Blocks?
ETC???
Arms?
C-Hubs?
Steering Blocks?
ETC???
I would get the Arms, C-Hubs, Knuckles, and replace the aluminum steering turnbuckles to steel or titanium ones. I would also replace the aluminum ball ends on the knuckle to the Tamiya gold ones. Those are made from steel. Also get a shim set, to remove play in many places.
Thanks Tony... Could you help me find the part Numbers? I'd appreciate it.
Thanks again!
Thanks again!
if anybody is interested in an NIB MRE, PM me. i don't officially have it up for sale, just thought i'd put in here first
i've decided that i need to stick with my MSX; besides, i'm lucky if i get out to a race more than 3 times a year!
vic
vic
Thanks again!
Thanks again!
Titanium turnbuckle 3x18mm: #53525
I bought a spool for my MSX, do I need a new centre pulley? or can I just install the spool and use my one way centre pulley?
You'll need a fixed centre pulley if you want full time 4WD.
eh, hierog: since your keeping msx want to buy my used one cheap? or you saving for a mtx-4
I really like the MRE and don't need the MSX anymore....
I'd replace the front axles on the MRE as well, with steel ones
Carpet set-up
Fellow racers,
I'm looking for a good set-up for carpet using rubber tires. RP's mostly.
I got a couple of tips from previous posts and saw the Mark set-up online but this is with Foam tires so I would like a complete set-up for carpet.
I have the MSX using the 3mm chassis. Come on now all you Nor Cal guys up there! You know who I'm talking about. Past TCS champions, etc. etc.
I'm hoping to get responses from back east would be nice and the U.K.!
All suggestion will be appreciated!
Thanks in advance!
A loyal Tamiya racer!
Thanks in advance!
They have a new Alu. Suspension Mount Spacer 0.5mm /1.0mm on sale
http://www.racing11.net/shop/index.p...sort=1a&page=3
Is it possible to convert a MSX into a MRE?
As far as I can tell, I need to get the chasis (top and bottom), the complete steering system an the front and middle new pulley system.
How about the rear bulkhead? Are they the same on the MSX minus the top heatsink brace?
Also are the belts the same?
Any input is very much appreciated. Thanks.
The rest are just minor parts that are already released as Hop-up parts by Tamiya.
You may want to get the belts from the MRE as well for the new pullies.
