Tamiya TRF415
Originally Posted by Ben.C
Well then....Keep us updated...
Yesterday another lost race always because of rear belt broken.....
My rear belts don't survive to my racing configuration : spool,Novak 4.5,foams,IB4200,high grip race track.
What mistake I do ? I think that the 415MSX is designed to run only with rubber tire or foam with stock motors.
Two 415's racing at my club, and and all have the same problem.
I waiting the new MRE, and I hope that Tamiya has solved the problem (I don't think), otherwise I'm ready to change car !
Nobody has my same problem ?
I'm very tired to lose race for a unreliable model !
Originally Posted by TryHard
Ben -
The MSX one-ways do fit... you just need to modify the pulley for the front, and use the old style layshaft for the centre.
The TA05 front and centre won't fit, as the belt is on the other side compared to the 415.
I was that Tamiya would hurry to introduce one way units for the MRE.
HiH
Ed
Thank you Tryhard, yes I'm running, since four months, only with black belts, but I don't finish a race with the same belt of start, yesterday on six run I changed two belts and in the last final I stopped the car after half race ... I tried all kind of tension, loose, medium, hard, but the belt broken always.
have you checked that the belts aren't rubbing on anyhing? It's possible that they could be rubbing on the suspension block.
I notice you also said you race on high grop track with foams... this more than likely putting a high amount of strain on the drivetrain. What setup do you run? spool, 1-way etc?
Need help Please
Hi Guy's
I really need your help with a question regarding set up of my MSX and my MS Please.
I have downloaded some great setups of you guy's and I just wanted to get a set up for both my car's, I really value your opinion here.
The track is grippy asphalt outdoor.
some tight turns with one long straight.
Very grippy
very smooth
I live on the gold coast of australia and it is very warm most of the year.
What I am looking for it mainly a suspesion,ride hieght,spacer, Camber type set up to start from. I will be racing in stock rebuildable 27 turn.
Any input would be great here.
I also use one way and sorex 36 with yokoma wheels and sorex B mediums.
Has some one got a setup sheet of there car what would suit me.
Thanks so much
Addam smith
Very grippy
very smooth
Thanks so much
Addam smith
Originally Posted by JAY_UK
Well 5 of us just got back from racing at Broxtowe. Weve necer been there and we finished 1st 2nd 3rd 4th 5th in 19 turn. 1st and 3rd(me) for the MRE, 2nd and 4th for the Corally RDX and last was an Xray T2! LMAO! Its not an easy track as its a converted buggy track and tbh, both the tamiyas need a new chassis plate now! Does anyone know who keeps them?
Originally Posted by TRFMAD
Hi Guy's
Very grippy
very smooth
Thanks so much
Addam smith
Very grippy
very smooth
Thanks so much
Addam smith
Well for the MSX try this one http://www.thard.co.uk/setups/TORC/05/TORC13.jpg
It's pretty much the stock setup... but if your running a one-way change go up a spring rate on the front springs.
Also try moving the shocks in one hole on the arms (to hole 3), and putting the front upper camber link in hole 3 on the bulkhead.
That should work pretty well to start with.
HiH
Ed
Thank's Tryhard
I love your website it's got great info on there. It's great to see guy's like you out there helping other's.
Best wishes
Good luck with your racing
Addam
Best wishes
Addam
Hi Tryhard,
I will check if rear belt rubbing on the blocks, but I don't think.
I run with front spool and fixed central pulley.
I have seen that with front one way the problem was less. However, at my club two 415MSX with the same setup and same problems .....
Hey Tryhard
That is a great starting piont for the MSX, Exactly what I am after, do you have a similar one for the MS
Thank's Mate
Addam
Thank's Mate
Addam
Hi all,
Anyone tried the TA05 one-way pulley and the TA05 front one way on the MRE??
Still looking for a way to fit a one way setup.
if you put it in without narrowing the pulley, it will bind the front somewhat, as it fits too tight between the bulkheads.
Hey Tryhard
Thank's Mate
Addam
Thank's Mate
Addam
http://www.thard.co.uk/setups/TORC/05/TORC2.jpg
Bear in mind though, Ashby is a pretty bumpy track. You could probably get away with going stiffer on the shocks, if as you say, your track is smooth. But that will be a good starting point.
HiH
