Inspire us.  Show me your BEST, CLEANEST electronics installation pics. >
Like Tree475Likes
Old 09-23-2010, 03:42 PM
  #1006
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by seaball
man, have i mentioned how much i love this thread?
and for goodness sake put some new shoes on those rigs after all that work!
keep it up folks. fun stuff.
You still racing man?
BlackedOutREVO is offline
Old 09-23-2010, 04:11 PM
  #1007
Armaan's Avatar
Trader Rating: 49 (100%+)
Originally Posted by AGNO
Wicked.
Armaan is offline
Old 09-23-2010, 04:37 PM
  #1008
js058515's Avatar
Great site, but does anyone know a link or company who sells just the sensor wire plugs. I have a handfull of 200mm and longer sensor wires that I would love to shorten for 12th scale use.
Originally Posted by blis
Having explored replacing wires I found most good servo's have the solder points coated and a tight job at that, so I went the other way.
Good ternimal crimper for servo leads and such http://www.hansenhobbies.com/ - get the ratchet version, you'll need it!
I've bought one, realised you wouldn't wan't to crimp with a cheapy and the end product is awesome. Lots of accessories there too. Service was great and watch the video it was most informative.
js058515 is offline
Old 09-23-2010, 08:23 PM
  #1009
Potoczak's Avatar
Trader Rating: 120 (100%+)
Pic of my latest touring car!!!
Attached Thumbnails Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-avid-2-pic-3.jpg
Potoczak is offline
Old 09-24-2010, 05:09 AM
  #1010
blis's Avatar
I'd say they were a pressed plug that you'd need a die for, after doing a standard Servo crmip, anything smaller would be beyond me.
blis is offline
Old 09-24-2010, 05:57 AM
  #1011
heretic's Avatar
Originally Posted by BCbud
Good day!
Here is some pictures of my CRC 3.1.
Hello, I remember seeing a pic of your car on another thread. You might want to check the downward angle of your steering links, because I suspect that they give you a massive bumpsteer. Might be wrong, of course, just thought I'd warn you. Nice good old ride BTW !
heretic is offline
Old 09-24-2010, 11:24 AM
  #1012
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Yes there is some downword angle there. There is no spacers under the lower arm for the half worn tires that are on it and when new tires are installed it will rase the suspention reducing the angle. I could still put in some specers at the top of the steering block to reduce the angle more but do you think it will make mutch differance with about 1mm of suspention travel?
BCbud is offline
Old 09-24-2010, 11:40 AM
  #1013
heretic's Avatar
YES ! The servo position and steering geometry has a very noticeable influence even with such little travel. To check if you need some spacer under the ball which is on the steering knuckle, turn your wheels and check the movement of the outer wheel when you compress the suspension. If it has the effect of "gaining steering", even a little bit, you have some bumpsteer that you should get rid of. The car is much harder to drive with bumpsteer, for obvious reasons
Have fun !
heretic is offline
Old 09-28-2010, 11:01 AM
  #1014
Robert_K's Avatar
So, I've been working on this car for a few day's now, but I'm starting to like it. The Sensor Cable en TQ-Booster still need to be switched for a "better" solution, but I can start now
I tried something new with the carbon:
Regards
Robert
Robert_K is offline
Old 09-28-2010, 11:11 AM
  #1015
JayBee's Avatar
Trader Rating: 31 (100%+)
That looks freakin awesome brah!! Great job!! What's the blue on the edges?
JayBee is offline
Old 09-28-2010, 11:13 AM
  #1016
M-Technic's Avatar
Trader Rating: 15 (100%+)
Wow, hats off to you Robert K.
M-Technic is offline
Old 09-28-2010, 04:06 PM
  #1017
mkdut's Avatar
Trader Rating: 19 (100%+)
WOW! The blue edges are sick! I might have to go buy a new kit just to do that. Blue nail polish?
mkdut is offline
Old 09-28-2010, 05:46 PM
  #1018
andrew-01's Avatar
Trader Rating: 22 (100%+)
M05 PRO
FF03 PRO
Working on a 12R5.1 as well.....Lets just say the blacked out wires will match the anodizing work by Owen Racing.
andrew-01 is offline
Old 09-28-2010, 05:53 PM
  #1019
Trader Rating: 25 (100%+)
not on road but here ya go,
rock addict is offline
Old 09-29-2010, 12:26 AM
  #1020
Robert_K's Avatar
Thanks Ya'all
I've sanded the chassis, and put some Blue FasKolor on it. about two layers, the more layers, the darker it gets.
Then some Much More Tire CA on the edges for the glossy effect.
Best Regards
Robert
Robert_K is offline
