SMC 40C+  C-Max 7.4V Hardcase Lipos >
Old 01-03-2009, 06:37 PM
  #136
kschu's Avatar
Trader Rating: 16 (100%+)
how i wish SMC 5000 lipo can fit into Serpent S400...
kschu is offline
Old 01-03-2009, 06:58 PM
  #137
Core Creations's Avatar
Trader Rating: 108 (100%+)
Yeah, TCS is 5000mah limit too. I was planning on getting one of the 40c packs, but I mayhave to wait.
Core Creations is offline
Old 01-03-2009, 07:31 PM
  #138
Company Representative
Danny/SMC's Avatar
Car manufacturers have been aware of the ROAR max case size for over a year now so they can make the proper changes to there cars to make the packs fit.
I never heard of a capacity limit before today unless your racing in a spec class. The ROAR rules with case size limit and safety tests should be what tracks use.
Danny/SMC is offline
Old 01-03-2009, 08:10 PM
  #139
c1 racin's Avatar
Originally Posted by Danny/SMC
The EFRA pack should be 138.5 x 46.5 x 23
I assume you want to know the case size to see if it will fit the EFRA rules. The 5200 will not fit the EFRA rules but we will be making a pack that will be EFRA legal. We expect capacity to be around 4200 with 40C+.
Any release info on this pack? .... thanks
c1 racin is offline
Old 01-04-2009, 02:09 AM
  #140
Thanks for the info. We will study this and see what we can offer as far as capacity and C rate.
We will be releasing a 3400/11.1V/20C hardcase pack.
Please keep in mind that the motor will surge as much as 2500Watt @22.2Volts.
As for runtime guys are looking for 5000 to 6000mah 11.1Volts (@ 40C)
Thanks for looking in to this.
Greetings,
Alex
alexx is offline
Old 01-04-2009, 08:39 AM
  #141
Danny/SMC's Avatar
Were working on the case design and we expect the release date to be end of February.
Old 01-04-2009, 08:42 AM
  #142
Danny/SMC's Avatar
Greetings,
Alex
We have 40C+ / 5000 flight packs coming out. One will be a 3S(11.1V) pack and will have the following dimensions H26mm x W44mm x L162mm.
This pack should fit the Revo.
Old 01-04-2009, 09:03 AM
  #143
tomracing's Avatar
danny,
are the definite case dimensions of the new 2s 5200 40C packs available and could you please let me know? that would help a lot.
also how will the power connection be the pack? will it have leads coming out like the other and if so where?
thanks!
tomracing is offline
Old 01-04-2009, 09:57 AM
  #144
Danny/SMC's Avatar
The case dimensions posted on the first page come straight from the drawings of the case so that will be the size. The wires will come out on top like our current cases.
Old 01-04-2009, 10:11 AM
  #145
tomracing's Avatar
great thanks!
sorry for not noticing the modification of the first page.
Old 01-04-2009, 07:40 PM
  #146
Oh man 8000 mah packs that fit the e revo would be
Awesome. I known allot of people that would be
Estatic. That truck has a pretty large following and quality
8000's are hard to come by. The slash could also use these
Dragonfueled is offline
Old 01-04-2009, 07:46 PM
  #147
Danny/SMC's Avatar
Do you have the dimensions of an 8000/7.4 that fits the Revo ? I also need the C rate.
Old 01-04-2009, 08:26 PM
  #148
gonzo416's Avatar
Trader Rating: 39 (98%+)
Danny, is there a reason why the mah's go up when the C rating goes up? because from what I see it requires a bigger case? I am asking because it would be nice to have a higher C rating and have them fit the 4000 28c case(20.5mm) for the T2 008 without modifying the topdeck.
gonzo416 is offline
Old 01-04-2009, 08:37 PM
  #149
Danny/SMC's Avatar
We have drivers using the 5000 in the T2 008 they just rest the pack against the topdeck. This has worked very well for them.
Typically capacity goes down when you increase C rate. Recently there has been some breakthroughs on materials that have allowed the C rate to go up while keeping the capacity the same. Our supplier has found a way to increase the capacity while keeping the size and C rate the same so this is why our 40C+ pack is now a 5200.
The 4000/28C will get replaced by the 40C+ EFRA pack when it becomes available. This pack will be a 4200.
Old 01-04-2009, 08:44 PM
  #150
gonzo416's Avatar
Will the dimensions be the same?
gonzo416 is offline
