Hpi Rs4 Pro 2
#151
Yoooo....anybody...
I can not believe that nobody did this for the Pro 2...
Greetzzz
Greetzzz
#153
Greetzz
#154
One way is to replace the steering knuckle with one where DCJ options exist. The other harder way is to make an adapter or bearing sleeve to convert the large bearing to a common 10x5x4 or 3mm bearing (or even a flanged bearing to ride on top of the large bearing?), then you still have the axle length to match.
#155
Thank rc square for your input...
#156
Checkout Mcmastercarr for sleeves that might fit...They have every dimensions listed there...I have made lots of seemingly impossible projects a reality with their help....Good Luck....
