Awesomatix EP Touring Car (A700 Shaft Drive)
#9168
Robinson Racing makes 49T/52T/55T/60T spur gears(48p)... You can get them at Amainhobbies, Towerhobbies, etc...
#9169
I use rw supa-light spur gears. They are available from 45t-105t. What motor are you using? I'd guess your probably using a 17.5 with that size spur. I run 17.5t blinky and use a 60t spur with a 29t to 35t pinion depending to the size of track
#9171
The prodigal son returns!
#9175
Congratulations Tom De Nardis for winning the the 2016 TFTR Master's (Melbourne) in Stock Class driving an A700 Evo II RFG!
https://www.facebook.com/awesomatixRC
#9177
AM05-3 rear holder of ABS can be installed on RFG after removing 0,5mm of material in two holes. AM42-3 FFG Links Holder can be installed over AM05-3 ABS holder in case of you need shorter top links on the rear.
#9178
R/C Tech Elite Member
Ran the car in a trophy event on the weekend, ran 21.5 got TQ, first final got the win, lapped traffic in the middle final wouldn't move and was taken out limped into 2nd with something wobbling, thought I'd fixed it, 3rd final, lapped traffic again, was coming back and then just stopped. Rear drivetrain had just bound up.
Stripped it all down and one siezed bearing, also some damage on the AM73-4 piece, workable or need a replacement?
