Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 06-09-2014, 11:26 PM
  #6556
95lscoupe's Avatar
Originally Posted by bertrandsv87
Do they make a Special wrench for that nut ???? I put a little loctite on mine....
Yes awesomatix does make a wrench for the nut. I put a hex wrench in one of the extra holes in the spur gear to lock it and give It a good tightening. Just don't tighten too much you can egg or break your spur gear. Since doing this I haven't had the spur nut back off.
95lscoupe is offline
Old 06-09-2014, 11:56 PM
  #6557
Smile
Thanks... I'll try to buy a wrench soon..... I think I used a set of plyiers on mine...
bertrandsv87 is online now
Old 06-10-2014, 06:09 AM
  #6558
KHoff7's Avatar
I appreciate the information.
KHoff7 is offline
Old 06-10-2014, 10:41 AM
  #6559
i ended up using a hex wrench to get it tight. i did not before so thats why it backed off. this weekend is the cascade asphalt series race #1 s i want to make sure the car is perfect.
dragonracing is offline
Old 06-10-2014, 10:46 AM
  #6560
Magnet Top's Avatar
Originally Posted by dragonracing
question, im running a spool on asphalt. whats the consensus, spool or diff on asphalt? the car feels good but pushes a tad on entry from the high speed straight slight right and then 180 degree right. im having to tap the brakes to set the car due to the push. i have disabled the front swaybar to counteract the push but im looking for a little more corner entry. upon exit if im smooth its a non issue but if i stab the throttle it tries to hook the car so i lose a little exit speed in trying to counter the hooking. thoughts? should i change to the diff?
Have you increased your rear downstop ( smaller value ) to allow more weight transfer to the front off power ?
Because 21.5 is a class that really is about maintaining speed I realize you don't want to get into the brakes much at all. To gain a bit on entry, as it goes to drag brake your car may enjoy some pro dive to cause a bit more front weight transfer under slight auto/drag brake. This shouldn't affect your exit on power hook issue. You might even be able to use your front sway bar again to get rid of the exit on power oversteer ?
So basically to add a bit of pro-dive, just add a .5 shim to the front -front most lower a-arm ball studs ( also raises your RC a little ) or take .5mm away from the rear of the front ball studs ( if you want to lower your front RC simultaneously ).
Or just adjust your downstop, if you haven't, . A little more droop , front and rear could do the job...
Jake D.
Magnet Top is offline
Old 06-10-2014, 12:31 PM
  #6561
thanks jake. ill take a look at my car and might try those adjustments this sat weather permitting. some of it also i think is that corner (you know the one at the end of the straight) i need to work on my entry a little more. its was better after i added the outer pipe so one can judge distance a little better at that side of the track. but i will try those adjustment you mentioned.
Old 06-10-2014, 05:22 PM
  #6562
Trader Rating: 44 (100%+)
Jake has made some valid recommendations. If you can locate the pro compound tires they will give you more grip over all and are faster than the d compound. What are you using for traction compound? Every form of r/c depends on tires so if you can start with that it will be a huge benefit. While a gear diff may help in the front I would at least run the front 1.0 bar and consider the following:
More front camber
More front caster (no more than 6 degrees)
Less rear tow (two should be min)
Lighter gear diff oil with only two gears
Metal gears in the diff
I have run a front gear diff over and over on asphalt and carpet and it just depends on the day if I like it or it's faster. Not a bad tool to have in the box but not really a first pick of mine.
My normal check list is as follows when making adjustments;
Tires
Tires prep
Body
Rear toe
Sway bars
Gear diffs
Front camber
Droop
Dampening/spring rate
I'm sure other have their order but this has worked best for me.
Monti
Monti is offline
Old 06-10-2014, 08:18 PM
  #6563
we are restricted to d compound tires only. i am however going to try a set of x patterns in a practice session to see if those help. mostly i think i need to adjust my driving line a little. but i am going to try the diff first.
Old 06-11-2014, 03:20 AM
  #6564
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Please try a lighter diff fluid (1k) and add some more rear droop.
hanulec is offline
Old 06-11-2014, 09:26 AM
  #6565
Hi guys,
after about a month of use in modified asphalt racing, I noticed that my alu chassis plate isn't totally flat any more. The left and right sides are about 0,2mm higher than the center of the chassis, where the stiffener is mounted.
Is this normal?
Awesoman is offline
Old 06-11-2014, 11:38 AM
  #6566
JayL's Avatar
is the new ball stud ST24L supposed to be threaded all the way up? Mine are not
JayL is offline
Old 06-11-2014, 11:48 AM
  #6567
Trader Rating: 27 (100%+)
FJ & Co -
Remember there was a post that measure out the TOP Ballends vs. standard pivot vs. short pivot ends.
Anyone have the measurements?
MDawson is offline
Old 06-11-2014, 12:54 PM
  #6568
will try lighter diff fluid in rear. my droop is 2.5mm to 3mm over ride height allready. is that going to be too much adding more? like 3.5-4mm? im at a 6mm ride height right now in the rear.
here is the setup but 6.5 rear and 6.0mm ride height and the droop has been compensated for the ride height. (increased=more droop)
Attached Thumbnails Awesomatix EP Touring Car (A700 Shaft Drive)-131117-a700l-bryson-tzgp2013-specgt.jpg
Old 06-11-2014, 01:07 PM
  #6569
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MDawson
FJ & Co -
The top ball ends are pretty much the same as the regular at21. The at21s is 0.5mm shorter
geeunit1014 is offline
Old 06-11-2014, 01:14 PM
  #6570
I would soften your front spring up a bunch. You already have a lot of droop, I don't think more will help too much. The front spring is pretty stuff though. Add 1mm to your B gap and try. Don't be afraid to really soften more as well, especially since you said you were running on asphalt instead of carpet
