Awesomatix EP Touring Car (A700 Shaft Drive)
#4682
#4683
#4684
#4687
The Aluminum chassis is lighter than the CF one !!! Wow... I guess it raises the CG then.... Interesting...
#4688
When I built the car it was under weight by allot... Now I have to add even more weight sigh...
#4690
Less weight at the bottom chassis level raises the CG, while more weight there lowers the CG.... It's obvious.... I think the aluminum has the flex that they're looking for on that track....
#4691
Transmission, motor, battery, all electronics are 1mm lower on alloy chassis as it has 2mm thickness only ( compare to 3mm of carbon chassis).
#4692
That certainly helps lower the CG Oleg !!! Nice.....
#4694
R/C Tech Elite Member
Freddy is looking good on and off track.
Great pics of his EVO car here-- http://ets.redrc.net/2013/11/chassis...ddy-sudhoff-2/
#4695
Interesting idea to use aluminum chassis, while others try to add more flex... Maybe it's only for high grip tracks?
