Warpspeed Demon and Demon 2
#1546
Great Job Brian, Stepped up into 12th Place. Good Job!
#1547
Way to go Brian!!! Great finish!
#1548
so who is going to the cleveland carpet nats. i will be there running my warpspeed d1 in stock foam
#1549
Hey all I'm back. Finished 4th in the main. I had a big lead on 3rd when I got held up by a backmarker for over a lap, and when i dove under him in the sweeper i got taken out . Wish Scotty would've called that one....
So i finished 4th overall, with pretty much an A-main car...VERY FAST.
#1550
I made the show at our local track also we had two heats of expert stock I qualified 4th and DFN'd In 19t we had 4 heats made the show there also qualified 8th and finished 5th . Didn't make the podium but I made the A main show's and thats good enough for me
#1552
R/C Tech Founder
Brian, try running that same setup but with less toe-in in the rear. I was thinking about it on the drive home; if your dual rate is set to 70%-80%, then you are getting plenty of turn in already; go down to 1* each side (or even less) and try it, or add a bit more dual rate. Another option is to go to 6* blocks in the front to compensate; especially if you are running the -2* of kickup (or whatever it's called) and 4* caster blocks currently; that means you only have 2* effective caster in the car.
I looked at some of the faster guys' TC3s at the end of the day and many were running 0-1 degree of toe-in on each side. Not saying that it's definitely faster, but it's something to try. My car was rotating just fine in the main, and my lap times were only about .1-.2 sec behind yours, and I'd attribute that to other reasons.
Anyway, just stuff to try. Good setup, though. Thanks for the battery tie down!
#1553
I'm deciding whether or not to share the dialed setup ....a wise friend once told me to keep it all to yourself because then you'd stay fast . Nah really all you team guys racing on foam/carpet give me a shout i got something for ya
#1554
Ya but shane did you hit 11.9's and 12.0's?
I was thinking for the nats to try 1.5 and/or 1 degree toe. That may have helped it through the corner a little bit at this race, but it was fast nonetheless. For lower/medium bite definitely keep the 2 degrees of toe to keep the car stable.
#1555
brian hit me with a set up for carpet so when i go up to rpm i can lay down the smack!
#1556
#1557
R/C Tech Founder
Stephen, for example, had 0* of toe-in at the rear.
I may be out of practice driving, but I do know a good deal of setup stuff. Besides, I'm just throwing ideas out there to help -- you liked my -2* of kick in the front! haha
