XRAY T2’009
#2071
I'm going to take my own advice and maybe try running without the foam and see if it helps or hinders. I'm going to be changing home tracks so once i get there, the testing will commence.
#2072
Does anyone know offhand if the smc 5200 24c lipo will fit the 009? I thought it said it was 23.75 in height when actually it's 24.75. I'm trying to do this with the lipo pads in place but without having to buy the lipo balance weight sets that offset the lipo if I understand it correctly. Thanks!!
#2073
Oh while I'm at it, if anyones got a set of the xray balance weights that have the brackets with it they want to sell please let me know. Amain is out now. Any other recommendations to offset a lipo in the 009 without this set?
#2075
Checked nexus already, out of stock as well.! Amain had them 2 days ago but at that time I was unsure on the smc 5200 24c or the thunder power 40c which had the humps on it. Well I chose the smc(hope I made the right choice, lol) which is a flat bottom pack so now I'd really like to have the balance weights! But I'll give your recommendation a try Thursday when I actually have the smc in hand! Thanks! Any chance you can post a pic of your install with the ppd plate?? Also, do most people go ahead and attach the ppd plate to the lipo? Or just drop it in and tape the lipo as normal without a plate?
#2076
I just so happened to pick up a ppd plate from a friend today! Looks like I'm going to have to do a bit of dremel work so it clears the post. So, if I understand you correctly, basically just use the ppd plate, slide the lipo just enough out to where the top deck doesn't even come into play and tape the lipo in??
#2077
Xray T2 009 shock bladder
Any one have a problem getting the shock bladder to fit into the shock body ?? Im having a nightmare with mine
#2078
I'm just sitting hear thinking that I'm real glad I'v still got my 09 and did not buy a T3, looks to me that the 09 is the still better car
#2081
#2084
#2085
Does anyone know if the t3 lipo backstops will work with the t2 009? I believe it's part number 306182. If it will fit does it offset the lipo like the balance weights(part 309860 I believe) do?
