3300 bettery charing questions >
Old 09-27-2003, 11:48 AM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Default 3300 bettery charing questions
Hi guys, I have been charging my 3300 battery at 5 amp the capacity read out usually shows around 3500 +- peak at 9.02 +- , i am just wondering will the capactity or peak voltage be different if i lower my charging amp to say 4.5 ? thanks !
Tag is offline
Old 09-27-2003, 12:05 PM
I think I was told by a matcher that you will only gain like 10 seconds for that little, your peak voltage will be lower also. It can't hurt to try it out once to see if it works for you or not and note how the battery performs at 5.0 and 4.5amps.
rwjso is offline
