Keyence Zero Extreme ??
I just ordered a Zero Extreme and I am confused about what the difference is between the 2002 and an EX. The individual that I talked to had a 2002 and the other, they were the same price but the 2002 had banana plugs instead of soldering tabs. This shop sells a ton of these so I am assuming it is the most recent version. Can someone enlighten me please.
Eric
Eric
Hmm interesting. I have the Extreme V with 2002 sticker. Anyways, the specs are the same on the Zero V Extreme and Zero V Ex-C. It just specifies JRM spec or European spec connectors (banana plug.)
here link with more info http://www.keyence.co.jp/hobby/english/speed.html
is it easy setup this ESC going buy one soon
been there
Yep i have seen that already....actually that is causing some of the confusion. It shows a 2002 sticker on both speedos. I have been told that the 2002 has terminals while the regular has soldering tabs...that website shows differently.
the Zero Extreme top one my stop told me that best one to buy. how much they selling it my stop it $190
I'm sure they are both the same, with the exeption of either plugs or direct solder.
I agree with Matt - The difference appears to be the manner in which the wires are connected to the ESC.
That's the first ESC I've seen with that plug type connection. It seems that I'd be easier to change wires when necessary, rather than sending it back to the factory as they suggest with the other one.
I and everyone that I know that has/have tried one really likes them, especially the Zero Extreme. In the US I've heard of the prices ranging from $175 - $200. I bought mine from a local hobby shop, so you can guess that it wasn't $175.=)
John Robb.
John Robb.
Hey Geppetto
I wonder if there are any advantages regarding electrical efficiency with either configuration. Does anyone know? Wish I knew I had the option.=)
John Robb
John Robb
they r the same except the connector.i used 2 have both versions...
