? about dish wheels/pave racing... >
Old 08-25-2003, 01:54 PM
dasgruvn's Avatar
Default ? about dish wheels/pave racing...
Ok,
so I've been practicing some road racing here @ Socal Raceway, i took a turn flipped *full speed* and tagged the pole. Shattered my new disc wheels. Anyways, what is a good disc to use on that sort of track.
hpi/yokomo or what? thanks in advance...
dasgruvn is offline
Old 08-25-2003, 02:45 PM
tamiya are good
trf racer is offline
Old 08-25-2003, 08:07 PM
Neil Rabara's Avatar
Default Re: ? about dish wheels/pave racing...
Originally posted by dasgruvn
Ok,
There are so many out there that will get the job done. I wouldn't recommend a hard compound, a medium compound wheel is good. You probably want it the wheels to flex under impact and return to it original shape. A harder compound will cause the wheel to break. Once it breaks, the whole tire is donel.
Neil Rabara is offline
Old 08-25-2003, 08:14 PM
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally posted by trf racer
tamiya are good
No way!
Tamiya dishes are as brittle as they come and shatter on impact.
(and this is coming from a self-confessed Tamiya freak... )
Scumacher RevLites seem to be a lot more resilient, but
even then I've managed crack a couple.
WC is offline
See
Trader Rating: 53 (100%+)
Orion makes a really good wheel that can take some good hits and not tweak or crack.
See is offline
Old 08-25-2003, 08:32 PM
Trader Rating: 82 (100%+)
where i run (track with PVC dividers), speedmind rims can take a beating - i havent wrecked one ... yet ive been using their 5-spoke wheels but im pretty sure they have a discs available.
marvi is offline
Old 08-26-2003, 01:04 PM
dasgruvn's Avatar
has anyone tried the discs made by Ofna? I think I will try those next.
dasgruvn is offline
Old 08-26-2003, 02:04 PM
gcooper's Avatar
I would 2nd it on the Tamiya wheels. I have not broke the dishes but have many that have bent, giving you that nice wobble effect. It wasnt even that hot of a day either and they bend.
Coop
gcooper is offline
Old 08-26-2003, 03:06 PM
Registered User
2Tenths's Avatar
I think whats most important for a wheel is one that will not bend. Crashes which break wheels are rare, so I vote for a rigid wheel. Tamiyas are good for this reason, and are cool also because you can get them with 0 or 1mm offset. Yokomos are similar and work well. Both are inexpensive compared to Prolines.
Wheels to keep as big a distance from as you can are take-off spoke wheels (bend city) and anything made of aluminum, which is too heavy. The new dish Take-off wheel is much better, but some of my friends in nitro broke them this weekend.
2Tenths is offline
Old 08-26-2003, 07:38 PM
WC
WC's Avatar
Up there when I said "break" I didn't mean shatter into a 1000 pieces like glass...
When your wheels start to wobble after impact... take a close look.
Chances are, they've gotten fractures and cracks which cause
the wobble. Sometimes its only the tyre thats stopping the
wheel from flying apart.
Best non-dish wheel I've bought so far is Kyosho's multi-spokes.
Made for the V1R, they're nylon super-tough and they have a
flat profile at the back - no reinforcing bits to snag your suspension.
WC is offline
Old 08-27-2003, 01:51 AM
Steevo's Avatar
I agree with WC.
While the Tamiya Dish wheels are excellent when new and spin perfectly true, they are very brittle and don't take well to even the slightest knocks. I have had several lose large sections of the outer rim after side swiping the boards.
steevo
Steevo is offline
Old 08-27-2003, 02:44 AM
avoid HPI/Hot Bodies rims at all costs.. they are pieces of shit!
my rear ones broke and i didnt hit a thing! damn thing broke in the center/hex area.. AVOID!
EDIT: talking bout the dishes.
versa is offline
Old 08-27-2003, 06:27 AM
Hotbodies wheels are awesome especially the inch ups I havent broke one yet!! and also HPI's are very good you must have had a serious crash or knock to have done that.
Ricky Copsey
prodriver is offline
Old 08-27-2003, 09:47 AM
dasgruvn's Avatar
so, no one has tried the ofna discs? I guess I'll find out tomorrow how they work.
dasgruvn is offline
Old 08-27-2003, 10:03 AM
John Fontaine's Avatar
I like the ofna dish...haven't had a problem with them mounted with Sorex 24mm's. I also like it cause it was black and came in packs of 8 for cheap
John Fontaine is offline
