Hudy Comm lathe hints and Tips
I just bought a Hudy comm lathe with steel v guides. first off it says that i should use a source of 4.8 volts if useing a battery. Does this mean i must use a 4.8 volt source if i am using a dc power supply? My other question is is there any tips or tricks to using the thing. How much should i be taking of the armature at first.
Regional Moderator
Try to remove only the tiniest amount needed to set the com true. Maybe .001 or .002 inches at a time.
anyone know where i can get one fixed ? my daughter dropped ours and now its hard to turn the bit across the com.
