"NEW" PROTOform R9-F Body
#226
#229
I thought lightweight bodies were "illegal" in big races now? Why use it in a club race if you can't at a big race? My baseball coach always told me "Practice how you play." Just my $0.01.
#230
Location: Colorado, USA, The land of the free and the home of the brave!
The price just caught my eye and made me wonder.
#231
R9-R Racebody
a_main_attendee;
- the jury is still out as to weather the LW laterial is "less durable", "as durable" or even "more durable" (believe it or not) I've heard all three opinions for the past couple of years. Personally I tend to agree with the "less durable" opinion. Bottom line is: just how good are the drivers that are drawing these conclusions. (??) Durability is never an issue with guys of Lemieux's or Baker's driving ability.
- as stated by Fred_B the .025 gauge lexan material is a "custom milled" - "special order" product, so it costs considerably more. Extra time and care is required in the vacuum forming process as well. (as a side note: Lexan is an oil by-product - and as we all know the cost of oil had doubled in the last year. This added expense has finally caught up with the plastic/lexan suppliers and us as manufacturers. Please don't scream if bodies go up a buck in price. The real recipients of that cash are Exxon and some camel jockeys that hate us)
- you're so right about the paint on that R9-R. It sure wasn't what I had been promised - not even close. Roly and my son Adam were just too buried with work. I'll be repacing it with one of Roly's "stunners" asap.
FOXY923
Lightweight bodies are still legal at large events in all classes other than Foam/Carpet classes where the "ultra-light weight .020" bodies had been used. In Carpet/Foam class specifically only Regular Weight .030 bodies will be allowed.
Dale - Protoform
FOXY923
Dale - Protoform
#233
LOW ET;
Technically, there's no actual GBS cut/trim line. The min. height allowed at ROAR, EFRA and IFMAR races is 115mm so I put a trim line that will help "get you in the ballpark" with the body height. (give or take a mm or two) The many independently staged races like the IIC, Snowbirds and US Indoor Champs don't have any min. height rule - so the guys are free to slam 'em as much as they want. At the IIC - some were slammed to the point of looking ridiculous.
(personally - I like the 115mm height rule for all sedan racing but..... )
INCIDENTALLY - The Protoform R9-F was used by all 10 of the Modified Sedan A-Main qualifiers at the IIC race in Vegas.
Ray Darroch gave the body its first ever A-Main win with his victory in the 10.5 main, with Keven Hebert's R9-F bodied car also on the same podium. It was a very satisfying debut for the R9-F to say the least.
Thanks guys
Dale - Protoform Race Bodies
Thanks guys
#235
R/C Tech Elite Member
just got my 2 R9-R bodys painted and mounted. i have a FT-TC4 and a Corally RDX, on both my bodies after trimmed there sitting about 1/2" - 5/8" from the ground. they look like crap. the R9 F body looks sweet on both cars and sets alot lower to the ground. is anyone else seeing this problem. love the body but hate the R version.
#236
touringdriver;
What you're saying about the 1/2 - 5/8ths inch clearance under the mounted R9-R makes no sence to me whatsoever. It should fit the same as the R9-F even with larger rubber tires because there's additional clearance for 63mm tires.
How much clearance do you have under your chassis plate? Did you adjust your bodymounts correctly? Do you have the proper shock tower on the front? What part(s) exactly is holding the body up that high? The one in the photo is sitting on a TC4 chassis with no clearance issues at all.
Dale - Protoform
Dale - Protoform
#237
I had no issues on my TC5 getting my R9-R slammed. The fit is awesome! I trimmed on the trim lines, mounts had to be dropped a couple holes in the front from the Mazda 6 I had mounted and IIRC one hole down in the rear. I could have gone yet another hole down front and rear but with a 5 - 5.5mm ride height I didn't want the body to touch the ground at full suspension compression. Trim lines are perfect - no need for major trimming in the wheel wells to avoid 'body tucks' and where mine is mounted it won't rub the wheel wells at all when the suspension is compressed.
With the R9-R mounted on the chassis it's roof and hood is still lower than just setting the Mazda 6 shell next to it on the table. I'll be running at the track with it tomorrow and can't wait to see how it handles!
I'm super happy with the R9-R Dale!
#239
i did'nt trim the body to be 1/2" off the ground. i trimmed them on the line. on my tc4 and rdx the body is sitting on the front shock towers. by all means guys i'm not dish'n the body. hell i love it. my problem is i trimmed on the line and it's 1/2 plus off the ground. tc4 droop is 5mm and 4mm. don't remember off hand on the rdx. i know the f body has several lines to choose from. but the r has only one line. so that takes the choice out of the equation.
#240
touringdriver;
Dale - Protoform
Dale - Protoform
