Tekin RS ESC sensored
#2178
Krio is on the right track. We've yet to see an application where running timing in the 50's at all.
Most applications find that around 35-45 is tops. Anymore than that simply creates heat.
#2179
has the speedpassion 10,5 spec motor a build in timing?
i can't change the timing on the motor so i thougt it was 0
how much timing has a lrp 10,5 ss motor? the one with the bleu ring.
#2181
the oudside diameter of the motor hous?
the diameter of the oudside of the motor diameter is 36mm
and the ring that you can turn arround is 32mm
#2183
the math is right, the units are backwards. it would be 1 deg = .314 mm.
#2184
the 4,5t lrp stands standart on 2 so 2degrees timing is also for the lrp
max 8 for the 4,5T
so 47 degrees standart and i can time it max till 55 for maximum speed?
max 8 for the 4,5T
#2186
ok and how much for a 10,5 lrp or speedpassion?
around 50 in total ok?
#2187
Hey guy,
Just remeber that the timing boost is really only for 10.5s and slower motors. If you're running say a 6.5 or other type mod motors you shouldn't be running any boost or excessive timing.
In general I run anything faster than an 8.5 in dual mode. The lower the wind the less timing is needed and desired.
#2189
Randy,
I need you to clear something up regarding timing. A while back you posted that when figuring out the total degrees of timing, you add the motor timing, the boost timing, and the 15 degrees that running in sensored only mode adds. Then Tekin Prez comes on here and says that because all motors are different, that there is no such thing as an automatic 15 degrees added by the sensored mode of the speedo. That you should only add the boost timing and the motor timing to get a total number. I'm confused. I'm running a 189 version RS with a 17.5 Pulse in 1/12 scale and I need to know which is the proper method of figuring out total timing.
#2190
Because each manufactures motor sensors report the info differently you can't just add 15 as the "hidden". I think 15 was a good number to use for us to be safe. So you'll probably never know "exact" timing when using boost. (it's closer to 5 to 10 degrees though)
BUT, the correct timing and boost is the one that runs the best and that is what's most important.
I always start with 0 motor 0 boost and start with gearing for infield then mess with boost for the strait. I found this to give me results the fastest.
