Tekin RS ESC sensored >
Old 11-13-2011, 09:27 AM
  #21256
Trader Rating: 15 (100%+)
Default Tekin ESC controls
Hey Randy, Whats the chances that tekin will make an app to hook my Iphone or droid to the esc to make changes at the track.
mdhyams is offline
Old 11-13-2011, 10:12 AM
  #21257
syndr0me's Avatar
Trader Rating: 32 (100%+)
You guys have been saying for 4 years now that the new software makes the Tekin "feel like an LRP." But it never does, you still have to pull the trigger 50% before the power kicks in like a light switch. Have you really finally figured it out? I don't want to waste time mounting one up in my car if it's still got the wiper ESC feel.
syndr0me is offline
Old 11-13-2011, 10:13 AM
  #21258
syndr0me's Avatar
Originally Posted by COLD AS ICE
Thanks Randy! I tried this today, no problems at all, my dad as well as a couple others suggested this. Thanks!
No chance, they'd rather blame Apple than look into Bluetooth.
syndr0me is offline
Old 11-13-2011, 02:55 PM
  #21259
Team Tekin
Randy_Pike's Avatar
I'm confident the feel is better. You'll have to drive it for yourself.
Blue tooth means adding either another module to the car or making a larger esc, neither of which we're to happy with.
We still feel the app is viable. Understand though none of the phones still allow for host control as an option.
We are not looking to please a small handful of drivers or people. We are looking to please the majority of them.
Randy_Pike is offline
Old 11-13-2011, 03:13 PM
  #21260
Default ESC
I say forget the blue tooth part. Its not worth the headache plus with bluetooth people could be changing settings on the move. I would be happy with a wired connection and I would be willing to pay for the software if the price was reasonable. Just wish I didnt have to bring my computer to the track.
mdhyams is offline
Old 11-13-2011, 03:18 PM
  #21261
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
i like bringing my laptop cause with my HTC EVO i tether it and use my phone as my internet and go online
20 SMOKE is offline
Old 11-13-2011, 05:32 PM
  #21262
Default Compatibility with Super High Response function of M11X?
As stated in the title, would anyone happen to know whether the Tekin RS/RS Pro is compatible with the SHR function of the M11X?
Appreciate..thx!!
mhavlena is offline
Old 11-13-2011, 06:29 PM
  #21263
warnos's Avatar
Default New Tekin motors
Late last year there was a whisper that there were some new Tekin Motors coming out in Mid - late 2011... any news on these?
Cheers
warnos is offline
Old 11-13-2011, 06:31 PM
  #21264
cannon's Avatar
Trader Rating: 35 (100%+)
Cheers
Early 2012 is the newe date apparently
cannon is offline
Old 11-13-2011, 09:10 PM
  #21265
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Has Tekin been winning with the same ESC for 4 years now.
My how time flies
RedBullFiXX is offline
Old 11-14-2011, 08:29 AM
  #21266
Team Tekin
Randy_Pike's Avatar
Appreciate..thx!!
Yes, not an issue.
Old 11-14-2011, 06:09 PM
  #21267
Dog Bone's Avatar
Hey guys, I recently purchased a Team EPIC D3 "Monster Horsepower" 13.5t to run in a boosted touring car class. I'm using a Tekin RS as a speedo.
I've got a problem where I have excessive 'drag' brake during corner entry. I quote 'drag' since I have no drag brake specified on the speedo. The only thing I can think of is that the motor itself is causing the drag. I've noticed that there's quite a bit of 'cog' in the motor when you rotate the wheels by hand - strong magnets, I assume.
I'd like the motor to run a bit freer; my first thought was to add some push control, but it (strangely enough) didn't have any effect. I know in 1/12 that push control works extremely well, allowing the car to roll through the corners better. However, it doesn't seem to have much effect with the D3.
Anyone have any suggestions? The drive train runs free, so I don't think the issue comes from that.
Thanks!
(I'm also going to post this on the DUO 3 thread, just in case someone there doesn't read the Tekin forum. Apologies if this offends).
Dog Bone is offline
Old 11-15-2011, 02:30 AM
  #21268
It can also be your gearing doing it (or perhaps a combination of the two). A very short gearing (high FDR) can give a natural drag brake feeling. With another speedo (not Tekin) I am currently running 17.5T boosted with an FDR of 7.2. When I let off the throttle, the car stops quite quickly, even though drag brake is set to 0 in the speedo, and the motor have quite weak magnets.
Nilks is offline
Old 11-15-2011, 05:45 AM
  #21269
Dog Bone's Avatar
Well, I'm geared at about 7.4. I know others at the track are geared similarly, and they don't have the same issue.
I can't mess around with spur gear/pinion combinations much, since there's only two spur gears that are available for the TC6, and I'm already running the biggest one...
Dog Bone is offline
Old 11-15-2011, 05:56 AM
  #21270
Pro10noob's Avatar
I have had a similar poblem with the X12 13.5 at high FDR.
I used push control and it was almost gone.
Car is much smoother to drive and it rolls much better true corners.
It also depends on how much mechanical timing your running on the motor.
With high timing on the motor it runs a bit smoother then with low timing on the motor.
This was with the X12 LRP motor.
Now i use the stock timing insert on the motor and 15 to 20% push control.
regards Roy
Pro10noob is offline
