Tekin RS ESC sensored
No, but I find it hard to believe it would run fine at the beginning of a race and then just decide to quit.
When else would they fail if not when being used.
I would say the FET's are at fault. At the start of the run they are cold and when they heat up the resistance increases. Would be interesting to check the on resistance when cold and hot just to confirm..
If the car was fading at a given point this could simply be the point to when the sensor port in the esc would fail to work. The fet's in the RS don't "wear" and they don't fade during a race.
If the fet's were bad, shorted, etc they would be bad/shorted right out of the gate.
Granted heat does increase resistance but there are far too many other factors involved here. The esc's today are complex inside. Micros, fet's and other components are working in harmony. If however you were to lose the sensors during a run on a Tekin, you will get much slower when this occurs. If this was "another" esc you would simply be dead on the track.
This isn't a complaint or anything as this is the first problem I have EVER had with a Tekin product and was easily fixed, I'm just curious what would cause it (feel free to get technical, that's what I want )
Been running an RS in boosted 1/12th for a couple of years now and has performed flawlessly through all the updates. A couple weeks ago I pulled it out of the 1/12th, stuck it in a borrowed RCGT car and switched it to blinky mode. All through the day I was WAY off the pace, despite having good gearing, set-up etc. advice from some fast guys. I just wrote it off as not having found the right set-up.
Then last weekend I put a boosted set-up on it for boosted 17.5 TC. It was SLOW. No boost, no turbo at all. I re-applied settings to make sure it took, replaced sensor wire, checked to make sure sensor LEDs were flashing, still no boost. Finally I did a factory reset, set it all up again and BAM, rocket power
So my questions are:
1. What would cause this? Does everyone have this problem when going from blinky to boosted?
2. Is there anything that could have been wrong with it in blinky mode to make it slow? Seems to me that no boost is no boost so it shouldn't matter but if it's possible a factory reset could get me the missing speed in blinky, that would sure be encouraging for possible future blinky racing.
Did you see full throttle lights blinking when you were having this issue ?
New Motor
Hey all. I'm in the need of a new 17.5 motor to combine with my RS. Using Turbo/Boost, whatever speed I can get out of it..... Was thinking a Tekin, assuming they are matched to the ESC, but does it really matter? Is there a better 17.5 out there? Trinity?? Speed Passion??
Cheers
Cheers
Try the LRP X12 17.5 Stock Spec on the 4 dot insert (-10). RPM from 7500 to 22000, boost 40 and turbo 15. Set up the delay to suit your driving styles, and gear it a couple of teeth less than what you would normally use. PM me if you aren't too sure.
This is similar settings we use here in SA
Just a question .You say to gear down 2 pinions or so but here everybody seems to gear up 2 or 3 pinions . have you played with this do you think i am over geared
I used to run a duo 2 at 28mm rollout and i am running my X12 at close to 33mm rollout (outdoor foam)
Anybody got any comments on this
Cheers
Cheers
Many thanks for any info.
With boost, it will turn a LOT more rpm. Though I think a bit lower rpm ranges would give you more snap out of the corners. I would try 3k-17k.
THe kV rating of the motor is based on zero timing. As you add timing, the rpm of the motor increases
