Lay down Dampers
I'm looking for any info on a ONroad 1/10th car that has laydown dampers. I know of the Predator that was done but is pretty old and hard to find now, but are there other types out there? I've got a particular type of racing class in mind where I need to get CG as low as I can (and becuase we build a metal cage around them the lower the better)....Any help would be appreciated..... Alternatively has any one converted a TC4 to a laydown type design...
The car you need to look at is the TA05 IFS. It is the only TC that I now of that lays down shocks (front shocks).
http://images.google.com/images?sour...=1&sa=N&tab=wi
I don't think that's quite right. The cylinders are inboard, but it may be moot as I think both ends of the shock float, making the whole thing unsprung.
Unsprung portion is whatever "moves" with the suspension. If the shocks were flipped around, the cylinders would not move with the suspension...
